Instrument Track Region: Adjusting Volume?
Hello,
How do I adjust the volume on individual clips/regions of an instrument/MIDI track? For audio clips (ie vocals) I know how to do it, bc there's a slider on each clip. However, I don't see such a slider for instrument/MIDI clips. When I try it using the drop down menu, I highlight a region on my instrument track and hit something like Edit--> Adjust Volume, it adjusts the volume of the whole track, not just the clip. Anyone know the right way to do this? Thanks! |
Re: Instrument Track Region: Adjusting Volume?
Clip gain is not a feature for midi information. You can however select to view your volume on the midi track, then select the clip, use the crop tool ( https://encrypted-tbn3.gstatic.com/i...Dg6QYoFTLxnv_g its the tool on the left with the 2 arrows pointing left and right and should also come up when using the smart tool (all 3 edit tools will be highlighted in blue as the image shows) when you are hovering your mouse over a specific area of the clip)and the volume will raise or lower for the selected clip only.... you will see this visually as the volume line will be adjusted for just the selected area.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
Adjusting level of a region within a track - like Media Composer | bigtuna | macOS | 9 | 09-08-2011 10:07 AM |
instrument track volume peaks when instrument volume knob is down | deadvisions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-12-2011 01:43 PM |
adjusting region on bar grid on video track (7.3.1) | Horsewater | Pro Tools TDM Systems (Mac) | 2 | 08-24-2007 09:14 AM |
Crash when adjusting Instrument track MIDI volume | Helge Krabye | Pro Tools TDM Systems (Mac) | 0 | 01-28-2006 02:33 PM |
adjusting region volume | tokyofan | General Discussion | 1 | 07-11-2004 11:18 PM |
