PT 2018.12.0 LLM overcompensting latency ?
Hello guys,
I'm experiencing some issues here. OSX is 10.12.5 PT 2018.12 In Low Latency Monitoring PT seems to overcompensate the latency, meaning that whatever I play back is a little bit ahead of what I recorded. When I turn off LLM it is correctly set. Changing the buffer doesn't affect this in any way. It's not getting worse or better. Whats the issue ? Thanks Sascha
PT 2018.12, Mac Pro, HDX, S3. |
Re: PT 2018.12.0 LLM overcompensting latency ?
Interface is an Apollo8 Blackface.
Thunderbolt. Seems like the Apollo is reporting the wrong latency to PT ?! Anyone ?
can you check if it is happening only on tracks that are record enabled?
If only I knew how to record on a track that is not record enabled...
seems like you didn‘t get it...
Gesendet von iPhone mit Tapatalk |
check if there is a difference in timing between playing back your newly recorded audio when the track is still record enabled and when it‘s not. also check the numbers in the delay comp window.
if there is a difference, then yes, it‘s a bug. go back to pt 2018.4. Gesendet von iPhone mit Tapatalk |
Pro Tools 2018.1 low latency monitoring issues | stakeoutstudios | Pro Tools 2018 | 61 | 04-15-2020 07:15 AM |
Low Latency Monitoring different in PT 2018.10 and HD Native? | katerkarlo | Pro Tools 2018 | 11 | 03-31-2020 01:50 PM |
2018.7 low latency Recording question | RobertDorn | Pro Tools 2018 | 3 | 09-28-2018 11:45 AM |
PT 2018 - Low Latency Monitoring issue: mutes signal | briaboy | Pro Tools 2018 | 5 | 06-25-2018 04:23 AM |
PT 2018.1 with MBox 3 USB latency | RichrdC | Pro Tools 2018 | 2 | 02-23-2018 04:39 PM |
