no way to vertical zoom on single midi note in pt7
Is there no way to vertical zoom on the single midi note view (eg: Octave 1, C1)
Horizontal zooming is not a problem, but it seems when you go into midi view= single note, vertical zooming of the track is disabled. This is a big problem when u want to edit the velocity of the track (no enough screen height) I'm on PT7 |
Re: no way to vertical zoom on single midi note in pt7
don c
filosofem
Aaron Mulqueen - 001 HD Native |
Sure i have about 10 midi tracks all set to view as single note.
Eg: c1, c2, c3, c4 etc. Each track is used to program a different drum part. When i want to add velocities of hi hat's and snare rolls, its pretty difficult because the track height does not increase when i am trying to zoom in. Btw, i know there's many other ways of programming drums, but i like this method. Any suggestions? |
don c
filosofem
Something I wish we had. I also wish we could make the 'piano' or 'keyboard' graphic a little bit wider. It's hard to see. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Yeah I just finished setting this method up, I'll tell you what, you'd have to setup some sort of template, for stuff doing that every time you require sampled drums. But once setup, very convenient, no mucking around with the piano roll, all your event data is right there, but yeah ...that vertical zoom ...what a pain in the posterior.
Maybe one of these might help. Feature Request Form filosofem
Hey Shan, do you know a quick key command, that would quickly switch to the normal sized velocity view, and switch back easily? Any workarounds to speed up work flow in this case, when wanting to edit midi velocity?
I have a drum grid of about 40+ tracks all set to one note and have been using this for a whiles. The only workaround for what i 'think' your trying to do is to group all your midi drum tracks and when you set one to medium eight etc all the others will follow suit.
BUT... heres the bit that SUCKS!.... you cant select one note view in a group. Only the track you are trying to set 'one note' veiw will revert to that state. There has been a couple of times i accidently changed the height of the entire 40 tracks and have had to manually reset them one by one!.... not fun Ive found that PT7 real time midi capabilities are pretty useful for midi drum parts. Check out the reference guide if you havnt and you might find some use there |
i'm still at 6.4, but can't you just add two new memory locations? check the 'track heights' box on both, set the time properties to 'none'. you could name them "single note" and "edit velocity". set the heights on the tracks then add the memory locations. is bueno?
[img]/images/graemlins/cool.gif[/img] Ob-La-Di Do Do Do, Ob-la-da Da Da Da [img]/images/graemlins/cool.gif[/img] they call me The Thread Killer |
JustMe
I just set that up and have run into a glitch, "edit velocity" works fine, but when returning to "single note" it will only return to a mini track height not to Single Note mode. Have you come across the same thing? Quote:
filosofem
How To Vertical Zoom Midi Regions View? | taylor4814 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-27-2009 08:00 PM |
can we detune a single midi note in PT 7.3? | siga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-31-2007 10:27 AM |
How to do individual MIDI track vertical zoom? | Mukaiya | Pro Tools M-Powered (Win) | 8 | 12-14-2006 07:33 AM |
Vertical single waveform zoom - not working | sonuslab | Pro Tools M-Powered (Win) | 7 | 10-19-2006 05:34 AM |
Single Note View MIDI | e-rase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-11-2006 06:46 AM |
