Old 08-25-2017, 02:57 PM
danyg danyg is offline
Default Re: soothe - dynamic resonance suppressor
using it every day with PT12 vanilla. such a quick modern and creative tool
Mac Pro 12 core 3.46Ghz - 64 Gb ram - SSD 500 Gb - HD1 2T - HD2 2T - OS 10.10. - Mac Book Pro retina- OS 10.10. - SSL Alphalink convertor - Pro Tools 12 native - SSL Matrix console - Logic Pro X
Old 03-04-2018, 03:28 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Originally Posted by Kristo Kotkas View Post
The only downside for me is that the latency is big[/URL]
I get over 8000 samples of latency.
I’m still demoing and debating if i should get it or not.
It’s a quick and great sounding tool but the latency is a workflow killer when tracking VI’s.
Wish it had a zero latency mode.
Zero latency mode should be mandatory for all plugins.
Old 03-04-2018, 10:28 AM
TNM TNM is offline
not a workflow killer unless you put it on the master fader or the signal path of the VI's..
I personally can't get good results with it after i impulse bought it on the BF sale last year..
I tried it every single day and tweaked every parameter possible.. I got a better result with a simple dynamic EQ every time.. I find it unintuitive especially designing the EQ band and overpriced.
But i'm obviously in the minority.
1) iMac Pro 3.2ghz 8 Core, 64GB Ram, 2TB SSD, OS 10.13.6, Caldigit TS3+ Dock, Startech USB-C raid enclosure w/ Crucial MX500 1TB x2, 1TB SSD-R G Tech x 2, Samsung 860 Pro 512gb Audio Drive in USB C Enclosure, TBolt Apollo 8 x 2, TI2 Desktop, MoxF6, tons more midi synths, PT 2018.7/Cubase9.5.
2) MBP 2.8ghz i7 quad, 16GB ram, 1TB SSD, OS 10.12.6, PT 2018.7, Logic 10.4.1,Internal Sound, TBolt SSD 512GB.
Old 03-04-2018, 06:44 PM
Sardi Sardi is offline
Default soothe - dynamic resonance suppressor
I could be mistaken, but I don’t think it’s possible to create a plugin of this kind without it inducing latency. It must have a lot of look ahead stuff going on.
Perhaps try using it on mixdown only and not when composing to avoid the huge latency?
Or you could commit the file to an alt playlist and then make the plug inactive.
It’s a fantastic plugin and well worth the money IMO. It totally transformed a disastrous drum recording I was sent. Would have been a PITA trying to remove all the resonances with an EQ.
Old 03-07-2018, 10:04 AM
WKG WKG is offline
Love what Soothe does. Mix tool only for me though.
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT HD 12 2018.7 REAPER 5.963
RME, Daking IV, ISA 428, Sytek, BLA
ASUS N71Jq i7 940xm 8GB DDR3
PTHD 12.1 REAPER - Win 10 HP
  #16
Old 03-07-2018, 10:57 AM
chrisdee's Avatar
Fabfilter has a DeEsser that works with zero latency. Isn't Soothe a similare kind of plugin but that works over a much larger bandwith?
Anyway I contacted support and they told me they have alot of request for zero latency and that they are looking into this.
They also said that for every halving the latency there would be a doubling of the CPU hit. So zero latency in it's current state would mean about 20x the CPU resources. I guess we are talking 18 cores or above to be able to run one instance.
Absolutely. That's how I'm using it now.
  #17
Old 04-04-2018, 07:22 PM
AlexLakis AlexLakis is offline
I wasn't able to get any musical results using it (rock drums/vocals). Clearly not for me. YMMV.
  #18
Old 04-05-2018, 08:05 AM
TNM TNM is offline
^this^
most overrated plugin ever, as far as i am concerned. Worst impulse purchase of 2017 for me.
  #19
Old 04-05-2018, 08:59 AM
WKG WKG is offline
Soothe is intended to target problematic resonances, I have found that it does that better than anything else I've tried so far. If you fortunately don't have problem resonant frequencies it is unlikely it will do much of anything useful.
One thing it's not is a color/shaping equal.
  #20
Old 04-05-2018, 09:16 AM
amagras amagras is offline
I haven't tried it yet, I think it follows the same principle found in the Waves multiband compressor and limiter, taken to its maximum. If that's the case it must be an amazing tool for those who use it. I should give it a try although I don't think is a good idea to try things I can't afford.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
amagrasmusic.com
HTML code is On
Waves NS1 Noise Suppressor superhunter2 Buy & Sell 1 04-28-2016 11:13 AM
Waves Noise Suppressor now available Studio Dweller Pro Tools TDM Systems (Mac) 21 11-12-2009 11:37 AM
192 voltage suppressor...help pls engineering? Jack Ruston UK Pro Tools TDM Systems (Mac) 0 10-12-2005 05:01 AM
What's SO dynamic about dynamic voice allocation??? jimlongo Pro Tools TDM Systems (Mac) 0 03-14-2001 02:52 PM
Resonance Filter TDM JLEpperson Pro Tools TDM Systems (Mac) 1 10-28-2000 06:44 PM
