Old 11-27-2013, 06:56 AM
applecore3401 applecore3401 is offline
Default Pro Tools 10 Midi Latency
To make this easy to understand I am gonna explain a simple scenario. In my real workflow I am using about 10 VIs and this is where this problem is happening.
I have a session click track and piano virtual instrument. I have quantized all the notes to the session grid. Within the first 5 minutes of working on the session everything is in sync and playing perfect with the session click. After 5 minutes the piano starts sounding before the click. I look at the notes and they are quantized with grid.
I am honestly bewildered by this. I don't know what to do and this is affecting my workflow dramatically. Any help would be greatly appreciated.
My Details
3.4 Ghz iMac i7 16gb ram
Pro tools 10.0
UAD Apollo Duo
Old 11-30-2013, 03:47 AM
Stig Eliassen's Avatar
Default Re: Pro Tools 10 Midi Latency
Are you using PT 10.0? There are a large number of issues resolved throughout the 10.x.x updates.
Does this happen with a particular piano VI, or to all VIs?
Old 12-02-2013, 12:19 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
I had that happen on one song in the past 3 years, where the MIDI was spot on the grid and after so long of playback at a certain bar the midi seemed to get out of whack... same session on multiple versions of PT yielded the same results, however I have many other sessions using the same template of VI's and longer song length with no drift. Not sure if this is corrupt session data or corrupt VI automation data, but it is rare that this has happened for me, last time I saw it before this session was like 5+ years ago.
May try making a fresh new session and importing all the session data from the drifting session to see if it solves the issue.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Old 12-02-2013, 03:07 PM
2 things I would look for here. #1-select Mix Window Shows and check the Delay Compensation option, and look at what is happening with ADC(assuming its turned on in the Options menu). #2-routing. Are you routing stuff thru AUX tracks for some reason(like making groups with submasters, or doing plugin processing to several tracks with a single plugin)?
Midi-latency with sample through Kontakt in Pro Tools. Lovah_lovah MIDI 8 01-29-2013 04:19 PM
MPC midi synced as master to Pro Tools 8, latency increases allen_gibberish MIDI 0 01-11-2011 03:41 PM
Midi Latency after using "Pro Tools and Databse Helper" michaiel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-20-2010 10:36 AM
Latency on Pro Tools LE Mbox 2 w/ mics and midi rickdrmmr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2007 10:25 AM
USB Latency and Pro Tools midi axiom MIDI 6 03-04-2001 10:12 PM
