Old 02-23-2009, 08:06 AM
applecore3401 applecore3401 is offline
Default Will Digi 002 upgrade fix all my problems....
I am having issues with my performance. I am running about 15 tracks with plugins on them and I am getting error messages like hardware buffer under-run. I am running the usb mbox and computer details are below. I have the hardware setting to 2048 so I feel i shouldn't be having problems. I am trying to figure out what I need to change in my setup to get more power in pro tools to run more plugins so I can mix. I am looking at either getting a better computer or the Digi 002. I want to know if upgrading to Digi 002 which has firewire is going to improve my pro tools system performance. Or do I have to upgrade computers? I know this is poorly written but bare with me because I am trying to get this problem fixed.
System Details
Macbook Black 2.4 GHz
Intel Core 2 Duo, 3 GB ram
Mbox 2
Old 02-23-2009, 08:25 AM
docbop docbop is offline
Default Re: Will Digi 002 upgrade fix all my problems....
MBox and 002 are just interfaces your computer is doing the processing that's generating those errors.
Steve B.
If you think you can or if you think you can't, you're right.
Old 02-23-2009, 08:57 AM
Resonant Alien Resonant Alien is offline
Your hardware buffer size may actually be set too high. Try a lower setting and see if you still have a problem
Old 02-23-2009, 09:12 AM
So if I buy the digi 002 the only thing it would bring to the table would be the additional outputs?
Old 02-23-2009, 09:13 AM
How can it be set to high? I thought setting it the highest gives you the best performance?
Old 02-23-2009, 09:27 AM
audiocase audiocase is offline
Sorry to hear you 're experiencing this ,but the setting can go both ways really. 1024 is the maximum in my case, so I suggest not to set it higher.
Consider the M-audio profire 610 ( much better latency) route before leaping to an 002 though.
BTW, did you make a clean install of v8?
Be ready to capture the magic... even in your sleep.
Old 02-23-2009, 09:49 AM
Sunzate Sunzate is offline
This isn't completely true, as far as I know.
I got rid of my (original) mbox and haven't looked back. It was a few years ago, but I had endless buffer problems, and the situation drastically improved when i switched to the firewire 002R.
Read the specs carefully: All except one of the mboxes (mbox pro) use USB 1.1, which is a slow, old interface. A quick google search reveals that the maximum speed of USB 1.1 is around 1.5 MB/s, while firewire approaches 50 MB/s. That's 30 times faster. More on the benefits of firewire (wikipedia),
Besides throughput, other differences are that it uses simpler bus networking, provides more power over the chain, more reliable data transfer, and uses less CPU resources.[23]
It's a vicious circle with an mbox. You get buffer errors because when you turn the buffer down to reduce latency, and you get buffer errors when you turn it up to improve performance.
Fail!
My opinion: If you are serious about recording, get firewire, or at least USB 2.0.
Hope this helps.
Adam
Adam White, composer.producer.engineer
www.studiocat.ca
Old 02-23-2009, 11:02 AM
DigiTechSupt's Avatar
The first question I would have is - what are the error numbers in the messages you're getting?
Also - what type of drive are you using for record/playback?
Have you tried any of the troubleshooting steps in the General Troubleshooting thread?
Avid Audio Tech Support
Support FAQ
Old 02-23-2009, 11:04 AM
TOM@METRO's Avatar
... and firewire... and lower buffer settings with less latency.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.6 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 02-23-2009, 12:17 PM
He's right - do these things first, but...
www.studiocat.ca
Digi 003 Midi Mode firmware upgrade causing problems DanielWiklander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-12-2012 03:24 PM
Upgrade Path from Digi 002 Rack to Digi 003+ bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-26-2008 03:28 PM
Digi Drive upgrade problems Tim Cooley Storage Subsystems 3 10-27-2007 07:28 AM
cpu upgrade problems acroyear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-19-2002 05:04 AM
PC Probe problems. Any overheatingg problems with Digi 001 Ajay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-03-2002 05:30 PM
