Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-25-2020, 06:32 AM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
Default Which post Sierra OS for latest Pro Tools?
I've been using Sierra on my main Mac Pro 5,1 tower for a few years now. It's got upgraded cores, graphics card, and 48gb RAM. Running an HDX card. I've used PT 2019.6 without any real hiccups. It gets beat 7 days a week with full bands and lots of midi stuff too.
Since I'm paying hundreds/thousands for PT each year, I figure I might as well build a new test drive with the latest PT. I haven't downloaded any of this years updates. I'm so blissfully out of the loop, I have no idea which newer Mac OS is good/dodgy. I know everyone's experience is diff. But if anyone has any thoughts post Sierra, let me know.
I know Big Sur (if it's even out) is not a good option. But maybe Catalina or Mojave will be ok. It'd be nice to update Logic etc on my main box... which I can't do since I'm still on Sierra.
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 11-25-2020, 06:57 AM
yanos yanos is offline
Default Re: Which post Sierra OS for latest Pro Tools?
With more or less the same system here is my situation http://duc.avid.com/showthread.php?t=412747
And here the Pro Tools OS compatibility https://avid.secure.force.com/pkb/ar...tibility-Chart
Maybe it coud inform you.
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 12.7.3 - Ram 64G - PT Ultimate 2024.3.1 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround)
Old 11-25-2020, 07:01 AM
JFreak's Avatar
JFreak JFreak is offline
Catalina works better than Mojave, in here ar least
Janne
Old 11-25-2020, 07:11 AM
Thanks JFreak. I guess I'll put that one on spare SSD and see what happens. Funny thing is, I don't even really care so much about the new features. Except for the SDII development, which would help when clients ask to work on OLD sessions. It happens monthly.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 11-25-2020, 07:13 AM
JFreak's Avatar
If for some reason Catalina does not work for you, consider High Sierra instead of Mojave. In here Mojave made things sluggish.
Janne
Old 11-25-2020, 07:57 AM
Ben Jenssen's Avatar
I'm with Janne, that Catalina feels very solid and snappy.
Just beware catalina and later needs "Metal capable" graphics, though I can't really tell you what that means.
SDII support came with 2020.9.1, or at least PT opens SDII sessions and converts audio automatically to wav. Not a minute too soon.
Old 11-25-2020, 08:20 AM
JFreak's Avatar
Mojave and later require Metal
Janne
Old 11-25-2020, 11:16 AM
c-tone c-tone is offline
The Avid compatibility documents show that only one Metal compatible GPU is supported for that computer , which, as others mentioned, would be required if you want to go above High Sierra. Keep in mind that some graphics cards require power connections and so does the HDX card.
Also be aware that your 5.1 Mac Pro may require firmware updates to upgrade to newer OS's, and there are specific steps required to do that, for example installing High Sierra before going to Mojave if I remember correctly. Check out the instructions and useful info here:
https://forums.macrumors.com/threads...hread.2142418/
Mojave is the last Apple supported OS on the 5.1 Mac Pros.
www.clifnorrell.com
Old 11-25-2020, 01:06 PM
I guess I lucked out in the Metal Dept. [insert Bevis saying "haha Metal"]. I just upgraded with an external power supply and graphics card last year. And in my system report it says "Metal: compatible". I've no idea exactly what model it is.
So Mojave is last "supported". But have folks used Catalina on a 5,1 and PT2020?
I don't do video work of any sort. once every 2 or 5 years someone does some sound for a Quicktime movie.
Brian
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
Old 11-25-2020, 01:43 PM
JFreak's Avatar
Google dosdude catalina patcher. Mojave compatible hardware is also Catalina compatible, just perhaps not supported
Janne
mid 2015 MBP High Sierra 10.13.6 and PT latest theAlps Pro Tools 2019 0 08-12-2019 10:02 PM
PT 12 on latest High Sierra paulschwotzer macOS 2 10-30-2018 09:45 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
exporting from itunes? (How to post on the "Let's hear your latest stuff" thread) Terry Wetzel General Discussion 31 07-19-2016 11:59 AM
Latest Digi 002 Model Number (is mine the latest?) JoyMODE101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-28-2005 08:05 AM
