Native Instruments Plugins load in PT
Hey Guys,
i reinstall PT 12.8.1 and my problem is that PT not seen the Native Instrument Plugins. So how I can load in this Plugins in PT??? I work with a MacBook Pro Retina (Mid2012) Thanks for ur help!!! |
Re: Native Instruments Plugins load in PT
You did what exactly? You reinstalled Pro Tools 12.8.1 over 12.8.1 or what previous version of Pro Tools? Why? To solve what problem?
What OS X/macOS version? Did you check all plugins and Pro Tools itself is compatible with that version? --- What NI products and what versions? You need a version that supports AAX-64 (not AAX-32 or RTAS) to run with Pro Tools 12. Are you running the standard installer to install the plugins? Are the NI .aaxplugin files actually in in the Pro Tools plugin folder? (after you run the installer). Do you see the NI plugins load on the Pro Tools startup splash screen? |
I had PT 12.8.2 before and there was all Plugins installed.
The program dropped it automatically in the PT system, but suddenly PT 12.8.2 didn't worked for some reasons. So i uninstalled PT and reinstalled the older one version 12.8.1 but without to dropped the NI Plugins. |
I have no idea what you mean by "The program dropped it automatically in the PT system"
--- Copy and past all the questions below and answer each one.. What OS X/macOS version? What NI products and what versions? Are the NI .aaxplugin files actually in the Pro Tools plugin folder? Do you see the NI plugins load on the Pro Tools startup splash screen? Trash prefs and databases (should do that automatically for any problem). Make sure you see Pro Tools do a full plugin scan when restarted. |
It doesn´t show me on splash screen during the load and I use the latest Plugins, if there in AAX I have no idea.
How can I seeing it if there in AAX? |
Look for NI .aaxplugin plugin files in /Library/Application Support/Avid/Audio/Plug-Ins.
Just trash prefs anyhow... |
no NI Plugins in there.
So how I can change NI plugins into AAX or how I can drop these into the Plugin folder?
--- You need to run the standard NI installers to install the plugins. make sure it's a version that includes AAX-64 plugins. Double check you have the correct/latest supported installers compatible with your OS and Pro Tools versions. It's not clear what you did here to remove plugins but next time it may be a good idea to ask before leaping in uninstalling stuff. |
They are installed in AAX64bit.
But I can't find them anywhere. The only thing I can is to open battery, Kontakt etc. as a single program on my laptop. So they working! But I as a insert they not there, and I have no idea in which folder I can find the NI AAX64 Plugins to put them into the PT Plugin folder. |
Native Instruments Plugins / PT 10 Issue | everlast88az | Pro Tools 10 | 0 | 11-19-2012 01:52 PM |
How are native instruments plugins on PT8. | chazc080488 | Virtual Instruments | 15 | 08-21-2010 10:50 AM |
PT 7.3 with Native Instruments plugins HELP!!!! | kindsounds | Pro Tools TDM Systems (Mac) | 0 | 07-03-2008 06:23 AM |
My native instruments plugins WONT LOAD HELP | The Grand Wizard | Pro Tools M-Powered (Win) | 1 | 07-26-2005 05:59 PM |
native instruments plugins | adam_w1 | Tips & Tricks | 5 | 04-19-2002 05:47 PM |
