I have a problem. So I've been scanning the DUC for nearly 4 months building my studio. Got the mics I want, drums are tuned the way I want them, and my digi001 and digimax LT are ready for some serious tracking. Problem is this, I need to experiment with mic placement on the drums to find the right sound, but the only way I can test mic placements is to place, record the drums, and play back. This sucks for me because I am doing it myself and need to run back and forth between my desk and set, which in this tight space is basically a pain.
So my question is, I know there are isolation headphones, but has anyone used them to sit at a drumset and monitor different mic placements? Do they block out the actual drum sounds well enough to hear how they will sound through the mic/headphones/mix? Thanks very much. [img]images/icons/smile.gif[/img] |
I too am a one man show, recording and performing at the same time. I find it really hard, especially recording drums. My DAW is on one side of the room, and my drums are at the other. It seens impossible but does anyonehave any ideas how I can record drums and play them too?
Thanks bassmac, those were some of the cans I was checking out. One question though - are those so sound-deading that it would affect my drumming while tracking? Should I use those just for monitoring or can I for tracking as well? Thanks in advance. [img]images/icons/grin.gif[/img]
the way to deal with getting drum sounds really si to record a bit and playback and listen. tedious yes, but it's the prescribed method.
Try to get someone to help move mics whilst you listen. Hope this is helpful. |
I tend go switch back and forth with my Sony 7506's (I think that's the model). Sometimes I just mute the record enabled tracks and monitor the drums simply by what bleeds in through the Sony's.
The Ultraphones are pretty dead, I'll usually monitor the OH tracks through them when I'm tracking. Or, sometimes I'll mute everything and just adjust the phones slightly off my ears for the right balance of bleed. I guess it just depends. They are worth having around though. |
Thanks a lot! Just ordered mine. [img]images/icons/grin.gif[/img]
I use shooters muffs, the plastic industrial type with a set of sonny walkman headphone taken of the band and stuffed inside. The sony's are about 15$. Get the ones with the bass boost.
This works pretty good for tracking. For getting sounds I have a pair of akg 270's I can crank up to listen to one sound source at a time for Mic placement ect.But watch your ears! [img]images/icons/smile.gif[/img] |
Could you get a USB extension cable for your keyboard so you can remote control PT? You might need a powered USB hub to drive the extra length.
This way you can control the record playback from the throne and avoid running around all the time
_ _ _ _________ _ _ _ Murray |
I run a second Kensington Expert Mouse Pro trackball over to my drums. The buttons are programed for start/stop & record. No getting up.
Monitoring with speakers and Headphones | oettinger1919 | General Discussion | 3 | 11-25-2009 08:06 AM |
monitoring w/headphones | quaintbs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-19-2006 08:09 PM |
Headphones for monitoring mixes | dividedsci | Pro Tools TDM Systems (Mac) | 4 | 11-11-2005 04:40 PM |
BEST headphones for monitoring???!!! | Anotherstate | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 10-18-2005 04:47 AM |
Headphones for nonsoftware monitoring | dogen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-23-2001 03:39 PM |
