8ch FireWire or USB Interface w/ PT MP9
I'm in need of buying a compatible 8ch Mic Input FireWire or USB Interface to use with Pro Tools MP 9.0.5. I've seen the following units however I can't find good online info. to confirm compatibiliy. If anyone can guide me to an online resource, I would greatly appreciate it. If you have experience, pros & cons with certain units, please let me know.
- Focusrite Saffire Pro 40 (read something about ASIO problems) - PreSonus FireStudio Project (old model was FireStudio) - M-Audio ProFire 2626 (read about Low Latency Monitoring problems) (I believe it's discontinued. What's replaced it?) - Mackie Onyx Blackbird - Steinberg MR816 X - Roland Octa Capture 10x10 System: MacBook Pro, OS 10.6.8, M-Audio FW410, Axiom 61, Yamaha NS-10 monitors |
Re: 8ch FireWire or USB Interface w/ PT MP9
Isn't Pro Tools MP a version that forces you to use M-Audio hardware?
http://www.avid.com/us/products/protoolsmp M-Audio appear to cutting back on their interfaces, you want my opinion, avoid them! Pray you never get a problem because their service is horrific!
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Dougfather is correct.
If you are using MP9, you are required to use an M-Audio interface, so that narrows your possibilities. It's only "regular" Protools that allows you to use any interface. |
So the ProFire 2626 is my only option for an 8ch interface. Does anyone know what limitation I'll have for sample rate trying to use all 8 channels at once? The max sample rate for PT MP9 says 96k although I've seen some notes out there stating I might not get that when trying to use all 8 channels on the ProFire 2626. Is there anywhere I can confirm what it really is?
I have a FireWire 410 which is M-Audio compatible. Can I add something like the Saffire Pro 40 via FireWire daisy chain to the 410? I don't believe the 410 has ADAT but will this scenario give me the added channels in ProTools MP9 to record?
No, because it will not recognize the Sapphire, being M-Powered. Again, you need regular Protools.
Problems with PT9 and FireWire interface | FT13 | macOS | 5 | 12-28-2011 09:38 PM |
1 interface, 1 hard drive, only ONE firewire interface? | beyoutofull1 | Pro Tools M-Powered (Win) | 5 | 11-22-2010 04:08 PM |
Firewire vs USB interface | Jeff E | Pro Tools M-Powered (Mac) | 1 | 08-12-2008 06:16 AM |
firewire interface | kav | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-01-2004 08:26 AM |
96kHz FireWire Interface | Tone | Pro Tools TDM Systems (Mac) | 16 | 12-19-2001 12:52 AM |
