Old 11-06-2016, 10:20 AM
sKjF sKjF is offline
Default Skipping playback (stopping/starting during playback)
I've recently encountered a problem I haven't seen before using PT, and I'm not sure what's causing it. I've recently started mixing a project , exported from REAPER with tempo info (actually, the only thing I can think might be the issue), that starts and stops during playback. What will happen is it will play for a short time and then just stop at random, but the counters (time, measure, etc.) will continue like normal until it all corrects and starts playing again. The periods between these "skips", if you will, are random and varying in duration. The period of silence during these "skips" also varies in duration. Sometimes the project plays right through, multiple times in a row. But most of the time, these skips occur, and multiple times per play. To give you an idea, a composition of slightly over two minutes takes nearly 5 minutes to complete, due to these "skips". I've tried searching not only here, but elsewhere on the internet as well, but can't seem to find anything that's actually related. I'm sure my inability to define the issue with a concrete term may be part of my difficulties in finding a solution, so I apologize if this is obvious or a repeat question. I would appreciate any help, or suggestions as to why this may be happening or how to remedy the situation.
Old 11-06-2016, 01:17 PM
Default Re: Skipping playback (stopping/starting during playback)
Help Us Help You Click this link near the top of the page. We need lots more info before anyone will have a chance at helping
Old 11-06-2016, 01:44 PM
Right, I was under the impression when I entered it in making the acct, it would display as a sig. Turns out it's just under "about me"... Here's the relevant system information, anyway.
Sager NP8678-S
Win 7 Pro SP1 x64
i7-6820HK
32GB 2133MHz DDR4 RAM
250GB Samsung 850 EVO M.2 SSD
1TB HGST HTS7210 7200RPM
PT 12.4
Harbinger L2404
Avid FastTrack Solo
Old 11-07-2016, 06:16 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi sKjF !
What audio interface are you using ?
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 11-07-2016, 11:25 AM
digibase digibase is offline
Originally Posted by jeam25 View Post
Hi sKjF !
Avid Fast track solo as from his Info!!
Are you having the latest drivers for ur fast track solo ?
http://avid.force.com/pkb/articles/download/en379411:-)
Old 11-07-2016, 02:08 PM
Terry Wetzel Terry Wetzel is offline
This sounds exactly like the issue I have had with my rig. (Pts 9/Win 7). I have posted it twice in the hope of finding a solution but none forthcoming. As you said it's random and unpredictable. For whatever reason, it has stopped occurring. I suspected it was a problem with the drive I was using for recording. I may have been right. it hasn't happened since I replaced the drive and the songs it would happen in were transferred to the new drive, {I'm still suspicious that it may reoccur at any time.)
Old 11-08-2016, 01:18 PM
Hi sKjF !
Hi, I've updated my signature and posted the relevant system info. in this thread. I use a FastTrack Solo, with powered monitors via RCA for output.
Sager NP8678-S
Win 7 Pro SP1 x64
i7-6820HK
PT 12.4
Old 11-08-2016, 01:21 PM
I would be inclined to try this, except that (as of now, and the previous year that I've owned PT) THIS is the only project to give me this issue.
Sager NP8678-S
Win 7 Pro SP1 x64
i7-6820HK
PT 12.4
Old 11-08-2016, 01:24 PM
The first thing I tried was an update via Devices and Printers>FastTrack Solo> Properties>Change Settings>Driver>Update Drivers. The link you provided is non-functional.
Sager NP8678-S
Win 7 Pro SP1 x64
i7-6820HK
PT 12.4
Old 11-08-2016, 01:25 PM
Problem still persisting, but thank you for your responses, all.
Sager NP8678-S
Win 7 Pro SP1 x64
i7-6820HK
PT 12.4
Loud clicks when starting or stopping playback tnipe Windows 36 06-10-2016 11:58 AM
Skipping During Playback Josh16 Getting Started 1 08-31-2014 11:59 AM
Playback Skipping thadjtig1 Windows 1 04-11-2013 05:11 AM
Skipping during playback ian Bourgal General Discussion 1 07-05-2009 11:54 AM
Skipping during playback JAH FYAH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-25-2007 02:00 PM
