Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
  #131
Old 11-03-2017, 09:51 PM
MichaelByrd MichaelByrd is offline
Default Re: Ilok key says its owned by another user.
Originally Posted by Bruce Paine View Post
Check the Private Message I sent you.
I cant log in to ilok cant remember security question was hoping you might have an idea on what I can try
  #132
Old 11-03-2017, 09:55 PM
What/who are you replying to? Bruce Paine long ago stopped working for Avid. If you've only posted one message on DUC how can he be replying to you suggesting you check private messages?
iLok is iLok, a different company than Avid, Avid staff can't help you with iLok account passwords. iLok support contacts are on their web site.
  #133
Old 11-16-2017, 09:54 PM
[email protected] williamika02@gmail.com is offline
Default Re: New iLok key says it's owned by another user
I also am having issues with this.
It says that my i lok 3 is owned by another user.
I purchased an I lok 3 and subscribed on avid to use the license on the new I lok but it says it cant transfer because the I lok is owned by another user.
How do I change the user if the I lok is brand new?
  #134
Old 11-17-2017, 03:16 AM
crizdee's Avatar
crizdee crizdee is offline
Take it back to the shop where you bought it and tell them its already been registered to someone. it must have been opened and used before you bought it.
Unless you yourself have registered it and forgot you done so and forgot the user name you used.
Ilok.com is where you need to ask support and they'll probably want screen shots of your ilok account showing the ilok in question. which will still show in the list of available iloks but as not registered to your account.
Chris
Producer, Engineer,
www.ukmastering.com
  #135
Old 12-01-2017, 05:26 AM
Marcoose1991 Marcoose1991 is offline
Hi Bruce, I'm having the same issue could you send me a message with how to go around it, had a mare getting the pace drivers to work now I've encountered the same issue. opened pro tools, it can see my ilk usb plugged in but i can select it.
  #136
Old 12-01-2017, 05:29 AM
Lots more info need. See the Private Message I sent you.
Hi Bruce, could you do me the honour of sending me a message aswell. perhaps slightly different in that i had my avid from an old friend, so i guess he still has it registered, however is there a way of removing or transferring the registration? thanks in advance.
  #137
Old 12-01-2017, 08:43 AM
Southsidemusic's Avatar
Hi
Bruce doesn't work here anymore but you should start a support case with Avid as that will be needed anyway.
Include all the info where you bought your copy and what steps you have done etc. The more info the better.
http://avid.force.com/pkb/articles/f...pport-services
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #138
Old 01-31-2018, 05:56 PM
surfwav3k surfwav3k is offline
Default Re: iLOK USB
My friend gave me his Usb Ilok key but it says Owned by another User. What does he have to do to remove the Ilok from his account?
  #139
Old 01-31-2018, 06:09 PM
jeffro's Avatar
jeffro jeffro is offline
Welcome to the community.
He should sign into his account with the iLok connected, deactivate all the licenses, then right+click the iLok and choose Remove iLok from Your Account.
• linkedin •
  #140
Old 06-07-2018, 03:29 AM
Pam Nil Pam Nil is offline
I have the same problem with the owner of this thread. can someone help me?
iLok owned by someone else PLEASE HELP bassgasm Pro Tools 12 7 07-21-2017 10:52 PM
Owned PT 11 since 2013, it's on my iLok, but can't get updates from Avid web mudixon Pro Tools 11 2 09-20-2014 12:48 PM
Do I really need to buy an iLok key to user PT9? uz3r Pro Tools 9 5 12-18-2010 08:12 PM
Changing your user name on iLok.com nmiller79 Pro Tools TDM Systems (Mac) 1 01-04-2007 08:12 AM
