Digi 002 Rack Not Booting Up
002 Rack
Serial #UA1967200F Imac Intel 10.6.8 Pro Tools 7.4 I've had my 002 Rack for about 10 years. I had the power harness replaced under warranty many years ago. It's given me consistent service since then. But now it gets hung up when I power it up. I can't select the mute button or the alt source to mon button. After warming up it clicks and appears operational and then dies again. Sometimes it works, sometimes it doesn't. It seems like a power supply issue. I'm wondering if it needs another power harness. Any ideas? |
Re: Digi 002 Rack Not Booting Up
Most likely is the harness, try taking it out clean all the terminals, grab some electrical cleaning fluid, once cleaned seat and reseat both ends of the harness over terminals, if it is not that could be firewire clip? Did happen to mine, dont hot swap f/w cables ever.
Cheers Mazzie |
Thanks I will try that.
Cleaned the terminals and still getting intermittent power failures: clicking on and off. Usually stabilizes after warming up, but seems to be getting worse. Clean again or do I need another harness?
Pretty sure it is your power harness, you could power everything down disconnect all p/cords, remove the harness again get some good electrical cleaner not crs and retry or contact avid for replacement
if your up to it check the solder joins under the power pin headers and re-solder if needed
if your not up to it find a local tech that is
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
So I've changed the power harness to the latest version and cleaned the terminals. It worked solid for about a week, but now it goes back to cycling the power and is pretty much unusable. Do you think a new power supply is in order or should just find a used one on Ebay?
For those who have booting issues with 002 rack | gwell1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-27-2014 08:57 PM |
Eleven Rack not booting stuck at logo | 31storguk | Eleven Rack | 23 | 05-04-2014 01:47 PM |
Eleven Rack not Booting in Standalone Mode | mjmurray | Eleven Rack | 2 | 07-16-2012 10:29 PM |
11 Rack vs. 003 Rack as interface when booting Pro Tools ?! | Sir Jamalot | Eleven Rack | 7 | 02-23-2012 03:51 PM |
Problem with 002 Rack booting up! | stuie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-08-2007 08:28 AM |
