Question about 003 analog outputs used with Reason, Sampletank, Reaper, etc.
I noticed when setting up the 003 to be used in standalone with Reason, Sampletank, and Reaper, it only allows you to pick from the analog outputs for the sound outputs. It doesn't let you choose the monitor outputs. I have my Mackie mixer going to the aux input on the 003. If I set these programs to outs 1&2 and connect the analog outs 1&2 of the 003 to the mixer to go back into the 003 and out to the monitors, will I get a feedback loop? Like is the sound gonna go out of 1&2, back into the aux, and out 1&2 again and again? Or is the aux in just gonna go out to the monitor out?
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Re: Question about 003 analog outputs used with Reason, Sampletank, Reaper, etc.
been usin' my 002 console in standalone mode with the products you listed for years thru the monitor outputs. pretty sure the 003 is the same in that monitor and mains outs are tied to outs1&2.
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Oh, ok. That explains it then. I thought only the headphone outs were tied to mon outs! Thanks!
suggestion...i have a 1604 mixer myself and i use it for routin' just about everythin'. but i route everythin' thru the inserts on the channels, that way i'm bypassin' the pre's and only usin' it for volume...not alterin' the sounds bein' routed. also one of the many things that Key pointed out to me is that there is a sonic difference, for whatever reason, between the monitor and main outs on the 002. so check it out on your 003 and see which one you dig the best
Reason, Reaper and AAX | DonaldM | AAX Plug-ins | 54 | 07-01-2013 06:21 PM |
Question on digi 002r analog outputs | kierkegaard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-21-2013 02:04 AM |
PT 11 with Reason and Reaper | DonaldM | Pro Tools 11 | 3 | 04-10-2013 07:11 AM |
Analog outputs -question | lumpo | ICON & C|24 | 1 | 01-29-2002 12:44 AM |
