Haswell build
i7-4770K
Cooler Master V8 Gigabyte GA-Z87X-UD5H Z87 LGA 1150 2-Way SLI Dual LAN ATX Motherboard Kingston HyperX Beast 16 GB Kit (2x8 GB) 2400MHz DDR3 PC3-19200 Non-ECC CL11 DIMM XMP Desktop Memory KHX24C11T3K2/16X Rosewill SilentNight Series 500W 80 Plus Platinum Certified Modular Design ATX12V/EPS12V Power Supply SilentNight-500 Runs tracking at a 32 buffer with a LS56 and large (50+) plugin/track counts at 512-1024. Overclocked to 4 Ghz static. PT 10.3.7 an 11.02 running with no crashes or lockups. The regular PT OS settings. DPC Latency 30-60 microseconds. Only issue with the motherboard is the supplied driver for the Marvell onboard disk controller is junk and throws huge DPC spikes. The Intel controller handles 6 drives so I just disabled the Marvell, but a new driver might be available. The memory is rated at 2400, but I and others found it runs better at XMP profile 2 -2133 If you use a FW interface this MB has a built in VIA chipset that passed the Focusrite tester. Also has a PCI slot. Very easy build and stable. Some info. on why I picked this over Ivy Bridge-E http://www.anandtech.com/show/6355/i...architecture/8 Would have waited for the 8 core Haswell -E's next year but my old system had other ideas. YMMV!
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra Last edited by dave911; 10-10-2013 at 12:33 PM. |
Re: Haswell build
+1 for Haswell info
________________________ www.PlethoraTone.com PlethoraTone Studio Video Tour At PlethoraTone: Mac Mini M1, Avid Carbon, PSP, Waves Mercury, UAD, Kush, Slate Digital, PA, Melodyne, Antares, Audioease, SoundToys |
Re: Haswell build
Wow. Great job, dave911 !!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Re: Haswell build
Nice are you running this as a hackintosh are you running Windoze?
Re: Haswell build
Running W7, be interesting to see a hack though.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra |
Re: Haswell build
Re: Haswell build
So how many cores does PT 10 see with your current config?
Re: Haswell build
PT10 sees 8, I'm using 7 as host processors at 99%.
New Imacs Out Today (Haswell) | nst7 | macOS | 2 | 09-24-2013 07:38 AM |
Any Haswell builds? | dave911 | Windows | 3 | 09-13-2013 08:42 PM |
DPC Latency in Haswell | dave911 | General Discussion | 8 | 07-17-2013 08:08 PM |
Haswell technical question for Avid | darbyclash34 | Pro Tools 11 | 11 | 06-03-2013 04:01 AM |
Haswell Processor - TSX or not | dave911 | General Discussion | 2 | 04-24-2013 05:19 AM |
