Avid i/o vs Audient 880 A/D conversion? Anyone have thoughts?
Hi all, I recently picked up a pair of used Avid 16x16 i/o units to give me 32 analog in's & outs.
My old setup was a mixtures of '192 Digital' units & Audient+Apogee AD16/DA16 converters. So to my question. Previously I routed a pair of Audient 880's digitally into the back of the first 'Digi 192D'. As my new AVID i/o interfaces only have banks of analog inputs, it looks like i'll be taking that route from the 880's into the Avid i/o (unless I spend more money swapping the analog cards for digital ones on the Avid rack). Does anyone have an opinion if the A/D conversion on the Avid i/o will be better , worse, or indistinguishable from the Audient conversion? (obviously I should a/b this myself but i'm very busy lol) Cheers
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
Re: Avid i/o vs Audient 880 A/D conversion? Anyone have thoughts?
Originally Posted by The Egg: Be a Pro and stop being a Tool! Mac Pro Rack (7,1) 16-core 3.2gHz Intel Xeon W OSX Catalina (10.15.4) 8TB Mac OEM SSD System Drive (3) 1Tb 7200rpm audio hard drives 192Gb RAM Radeon Pro Vega II Video Card 2 Avid HDX Cards 2 Avid 8X8X8 HD I/Os; 2 Avid 16X16 HD I/Os PT Ultimate 2020.3 |
The only "advantage"(in quotes as I'm not sure its actually good, bad or doesn't matter) to using only the 192 converters is that all will be sample-accurate for timing. When mixing converters, its possible that different brands might have slightly(on the order of micro-seconds) more or less latency. If you are feeding all the outputs to a console(mixing outside the box) and you had, say a batch of drum tracks, and some came thru the 192 converters, while other channels came thru the Audient converters, you might get some phasing issues. You can certainly make hit recordings with either or both
I use a Midas XL48 for my drum "shell" channels and started with it connected via lightpipe. Now I run it analog(overheads are thru a Focusrite ISA428 via analog) and I can't say I hear any difference(I mix all ITB)
p.s what are your thoughts on the 'soft limit' function? is it helpful/musical, or best switched off?..i've always liked it on my Apogee AD16 as a safety-net, although I obviously avoid having it kick in whenever possible..
I always have soft limit turned off, because whenever I would have hit it, I have already tracked too hot.
Just a reminder... 24bit WAV has 144dB dynamics. Your converter has "124dB" if it's really good. That means 144-124=20dB headroom if you use the full potential of your AD converter. Which means if you track hotter than -20dBFS you're only amplifying noise and going too hot means trouble for your converter anyway. Yellow is the new red. Period!
I know that sounds cute and easy to remember, but those color bars are changed or can be changed in the preferences dialogue. Give him a number don't give him a catchy phrase -20 to -14 is fine that is the new yellow
Yes! That is already on "red" if your converter is not better than +124dB
That's why I said give him a number, b/c color doesn't mean too much
Waves and Avid new licensing thoughts | musicman691 | General Discussion | 1 | 10-27-2014 01:52 PM |
AVID HD option vs Audient ASP-880 vs UA 4-710d | Firechild | Pro Tools TDM Systems (Mac) | 3 | 09-16-2014 01:52 AM |
Thoughts on IMPACT by AVID | philip888 | General Discussion | 11 | 11-01-2012 09:28 PM |
Any thoughts on Audio Conversion Software? | LonestarHawkeye | General Discussion | 1 | 01-15-2012 06:52 PM |
Avid Migration thoughts | paulmitch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-24-2010 07:26 AM |
