Old 01-15-2015, 08:12 PM
strat58 strat58 is offline
Default Eleven Rack and Re-amp to a "real" amp
I've searched for this, but haven't had any luck.
I would like to take my dry signal and re-amp with the 11R to one of my amps.
Then if possible, use the mic input on the 11R and record it.
Is this something I can do?
I know I can re-amp using the 11R as the processor, but I just want to send a dry signal from PT11 to one of my amps, then record that with a mic back into PT11.
Thanks.
Old 01-15-2015, 08:45 PM
Default Re: Eleven Rack and Re-amp to a "real" amp
Yes, you can easily send a recoded dry signal out the amp1 or amp2 outputs to reamp this though any external amp and mic that back. This exact scenario is briefly but clearly described in the Eleven Rack User Guide, so time to open that up and have a read. Should be clear, but ask any questions if it is still not.
Old 01-15-2015, 08:58 PM
Thanks, I'll take a look at the manual. I just wanted to make sure this is something the 11R is capable of.
Thanks.
Old 01-16-2015, 04:44 PM
JacksonRR1 JacksonRR1 is offline
See pg 88 & 89 here: http://akmedia.digidesign.com/suppor...v801_62404.pdf
Eleven Rack not recognized by Macbook Pro as a "Sound" device spc777 Eleven Rack 3 09-10-2015 09:11 AM
Eleven rack expansion pack serial "already activated" pieroft Eleven Rack 31 12-30-2011 04:37 PM
Eleven rack (11R) slow booting past "setting up midi" Edleigh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-25-2011 09:44 PM
Do I need the "Transfer Ownership Audio" form to sell my Eleven Rack? acmost General Discussion 5 04-16-2011 12:07 AM
Eleven Rack "Unable to locate Digidesign hardware" efisch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-07-2011 03:18 PM
