Tab To MIDI Notes Totally Dead in 12.8.2?
So, I paid the reinstatement fee to get back from 12.4HD to 12.8.2HD only to find that tab to MIDI notes is totally dead now in the latest version? I mean, it's been steadily getting worse in all the versions, but now I can't even do it all...
If there's a setting to fix this, can someone please kindly let me know what it is? I'd love for it to behave the way it did in PT10HD... Thanks! Sig |
Re: Tab To MIDI Notes Totally Dead in 12.8.2?
cheers john
Tab to transient is probably shut off in your toolbar
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Tab to Transient is not turned off...if I click the MIDI note, I hear my sample...I used to be able to tab to MIDI notes and it would play. The little MIDI to Speaker icon is lit too, as it's supposed to be.
I can't even tab to select them so that I can use nudge values to slip them a few ms ahead or behind...why did this change? What else is turned off that I'm missing here? Last edited by Siegfried Meier; 12-07-2017 at 09:56 AM. |
Sometimes you have to consolidate the midi clip and make a fresh clip and it will work again.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
Yes, I know this trick very, very well...however, I tried that and still no go...
Tabbing to MIDI notes jumps to the beginning of each note, but no longer selects it...and that's the reason the note isn't getting played. This was working fine in 12.5HD before we did the reinstatement thing...did I just pay a grand USD to have the software work worse than before? Also, when I'm editing drums and I cut 2 regions and try to quantize them to the grid, only the first region now snaps...the second one has to be manually snapped too. Not every time...just sometimes...that has NEVER happened before either, and I do this a lot... I did say I would get myself to the end of 12HD, and then I'd likely be out because I'm certain 13HD will not include, or will force us to surrender our 10HD license. With these bugs in existence at 12.8 at what I think is the near end of the 12 software cycle, I can say with certainty that my plan to stop supporting AVID from this point forth is the right path. Shame, after a 20 year run I've seen a lot happen to this company and software, but nothing works how it used to anymore and I find myself struggling more and more just to get projects done in any new version. |
What!? When and why was this changed??
And more importantly, why does no one who is telling me above how it's supposed to work know this?!? |
You did not specify you wanted the notes to "play" until later in your posts. That is when I told you the difference. It will still "tab" to the next note as you originally asked. The note selection otherwise works differently (and works as it should have all along) now using the arrows and modifiers. It is part of the midi package added to 12.8.2. With every new release, they have "Whats new in Pro Tools x.x" documentation where this is all gone over.
Tab to Midi notes ALWAYS implied that they were selected, which in turn meant they were being played. This has been going on since version 8...
I don't love this new addition, but at least it works. Thanks, Sig |
Stop MIDI notes from overwriting other MIDI Notes? | tjs5200 | Virtual Instruments | 4 | 06-16-2017 04:01 PM |
Totally dead D command fader pack | not2tech | ICON & C|24 | 2 | 08-26-2014 07:02 AM |
ADC midi timing totally off | damasio | macOS | 9 | 06-17-2014 11:35 PM |
Recording Midi notes and keeping existing notes during record | Sherbert99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-15-2008 09:40 AM |
Totally OT ;) Pod midi problems, please help | imi | General Discussion | 0 | 07-28-2006 01:54 PM |
