Old 03-25-2010, 01:02 PM
albanyboden albanyboden is offline
Default melodyne and data to midi for drum replacement?
Anyone know if you can use Melodyne to do data to midi for drums and how accurate it is? Looking for something to replace Massey and ideally keep it all still inside pro tools rather than having to go outside pro tools with Drumtracker... I wanna trigger other software with midi but have it follow velocity and such....
Old 03-25-2010, 01:21 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: melodyne and data to midi for drum replacement?
Melodyne does it, but its fiddly and you have to use the studio standalone version not the plugin.
Looking to replace Massey? do you mean DTM? you have the best audio to midi converter there, why do you want to replace it?
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-25-2010, 01:25 PM
dkstudios dkstudios is offline
melodyne is sketchy for drum replacement like that...especially midi....lot of drift...........Massey is numero uno in my book.......like dude said...you need the standalone version........
Old 03-25-2010, 02:47 PM
WernerF WernerF is offline
Melodyne is, for sure, drifty in the timing department. It's great for tuning voices but never puts the final fix back into P Tools exactly where it originally sat. With vocals it's really not noticeable but with anything percussion related, especially a drum sample that has to line up with the original sound, it is way too inaccurate.
Also, what's wrong with DTM and why would you want to replace it? It's already dead on.
Old 03-25-2010, 03:08 PM
studiojimi's Avatar
studiojimi studiojimi is offline
from what i can imagine...not much
but with it's botique status
if you don't have it you can't get it.
that needs to change huh?
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 03-25-2010, 03:27 PM
thanks, guys! the reason i'm looking for something is because i don't have massey dtm on my rig : (... any suggestions as to what to get in order to accomplish the same result?
Old 03-25-2010, 03:34 PM
Yah, you're right, circumstances have made it a bit exclusive at this point. The new version is apparently in the pipeline though. It just remains to be seen what the specifics of the product the timeline of availability are.
Old 03-25-2010, 03:43 PM
The only other software that can do this is, as you mentioned, Drumtracker and it does it very well. If you had DTM you'd have to go outside of P Tools the same way you would with Drumtracker which pretty much makes it the closest alternative.
Drum replacement - midi triggering Freezestudio macOS 2 10-28-2011 01:46 AM
Audio To Midi, Drum Replacement KroNEe MIDI 3 04-21-2011 10:07 PM
Another midi/drum replacement question (sorry) vocalize Pro Tools TDM Systems (Mac) 2 09-19-2005 09:42 AM
Melodyne as a replacement of Auto Tune Valeri Pro Tools TDM Systems (Mac) 2 09-25-2004 04:39 PM
Drum Replacement ivet Tips & Tricks 5 04-30-2001 11:48 AM
