Old 02-25-2014, 10:23 AM
Earl D Earl D is offline
Default Can newer PTLE always process older PTLE sessions?
I am installing PTLE 8.05 to support my 002 and 002r. I have been using PTLE 6.9 forever no problems. Can I record a session with 6.9 and mix it with 8.0.5?
Old 02-25-2014, 10:33 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Can newer PTLE always process older PTLE sessions?
Yes
chris
Producer, Engineer,
www.ukmastering.com
Old 02-25-2014, 11:55 AM
Indeed^^. The potential stumbling blocks are; moving from Mac to PC or back(pre-PT7 had an option to enforce PC-Mac compatibility and lots of folks would forget or skip that little detail) and, many Mac users in the old days would record in SD II format, which a PC can't read without conversion. Assuming you are on the same platform(Mac or PC), you can move a session between PT versions, and even between LE and HD/TDM versions
Old 02-25-2014, 12:02 PM
The Weed's Avatar
The Weed The Weed is offline
If they are indeed SDII, look up Rail Jon Rogut's sdTwoWav app.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
PTLE 8 on a newer mac mini wacissa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-12-2012 06:14 AM
Importing Newer sessions into older versions dannydog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-12-2012 05:33 AM
Txfr PTLE 5.1 Session FIles to PTLE 7.3 Sessions MITD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-23-2007 05:22 PM
PTLE 6.7 and older PT sessions lwilliam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-30-2005 10:24 PM
Installing older version of PTLE over newer one? xeetstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-29-2004 03:40 PM
