Old 03-15-2011, 09:35 PM
emmen emmen is offline
Default No MIDI output in PT 9.02
I just finished a clean install from scratch of Win 7 64bit and PT 9.02 (9.0 first then the update including the new 003 drivers).
I have a Factory 003 but I'm planning on using my Yamaha Motif XS 8 workstation as the Playback Engine - since I can get 22 channels of I/O as well as MIDI through the Yamaha Steinberg I/O driver.
Everything works perfectly except for the MIDI output. I get all the audio channels and MIDI in - but no MIDI out, whether playback from a MIDI track or MIDI thru from the synth.
I know the Yamaha drivers are working because I get MIDI out in other software - just not PT.
I tried the Yahama USB driver next - same story. MIDI out in any other software except PT.
The only way I can get MIDI out to work is by using the 003 MIDI ports with old-fashined MIDI cables.
Any thoughts here?
Thank you,
emmen
Dell Inspiron 530
Win 7 64bit
Factory 003 and/or Yamaha Motif XS8 Workstation
Pro Tools 9.02
Old 03-19-2011, 01:55 PM
Default Re: No MIDI output in PT 9.02
Bump.
I still have no MIDI output in ProTools 9.02
I'm sure there could be some basic things that I could check, prefs to throw away, drivers to check, ect...
Please help me out.
Thank you!
Dell Inspiron 530
Win 7 64bit
Pro Tools 9.02
Old 03-19-2011, 07:00 PM
TOM@METRO's Avatar
Are you using instrument tracks?
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-23-2011, 05:52 PM
andrewdin123 andrewdin123 is offline
Im having the same issue as emmen, with a slightly different setup. I just export midi files from sibelius.
I am using instrument tracks, and the plugins make noise when i click the drums or keys exc... Just not when i press play. Everything is good in my mix window. And I get audio playback just not midi.
Old 03-25-2011, 11:54 PM
My problems were solved after throwing away the pref files. (never was using instrument tracks)
Dell Inspiron 530
Win 7 64bit
Pro Tools 9.02
Old 03-26-2011, 10:16 AM
Unhappy Re: No MIDI output in PT 9.02
I deleted my pref files too with no luck...
Old 03-29-2011, 02:10 PM
BilboMcP BilboMcP is offline
I have exactly the same problem using a Cakewalk UM-3G midi interface.
I get midi in but no midi out.
As I use a Radikal midi controller that requires both in and out I am a bit stuffed.
Old 03-29-2011, 04:13 PM
Well I reinstalled protools, now the only thing thats giving me issues is superior drummer. You guys should give it a shot maybe...
Old 03-30-2011, 02:46 PM
Found my problem was due to using USB extenters and a hub.
Connecting the MIDI interface directly to the computer solved the problem .... but generated a wiring issue as my computer is in the machine room so I now need to run 4 long MIDI cables ..... oh well ..
Old 03-31-2011, 09:53 AM
Spoke too soon ... I still have midi out issues with all my interfaces.
I did notice that there are scores of entries for my Cakewalk [Roland] interface in the registry??!!
I have Win 7 64bit .... still works fine in Cubase
Single MIDI Track Output to Multiple MIDI Channels? jb_trm Pro Tools 9 2 07-11-2014 09:09 AM
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
MIDI Output Problem - Assigning MIDI Patch Names pancake1975 MIDI 8 05-29-2006 03:25 PM
2 MIDI Input Tracks Output to Same MIDI Channel altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-05-2005 03:20 PM
Help No MIDI Output HarmoniesBrass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-16-2004 07:22 PM
