Old 01-29-2010, 06:33 PM
Denny Jagard Denny Jagard is offline
Default Profile and SC48 interchangeable? Preamps same?
Are the preamps the same in the SC48 as the Profile/Venue systems? If a vendor can't get my preferred Profile, will my IEM mix sound the same on a SC48?
I'm sure I can figure out the work surface, and I'm stoked the software is the same, but I'm wondering if things will sound different due to preamps or any other factor I haven't considered (I only use standard plug ins, and I use the AES jumper to make the stereo bus my cue/monitor).
Sheldon feel free to email me, I'm kinda in a rush to draw my line in the sand for a Japan/Australia tour.
Thanks,
Denny
denny@dennyjagard.com
Old 01-30-2010, 08:31 AM
sonicboost sonicboost is offline
Default Re: Profile and SC48 interchangeable? Preamps same?
This was covered in another post somewhere here, but I don't remember were. I do remember the bottom line was:
#1 - the preamps are not the same
#2 - in blind tests there was no audible difference
Hope that info is helpful.
CONFIDENT IN CHRIST,
Eric Myers
Old 01-30-2010, 01:20 PM
digidesigner digidesigner is offline
http://duc.digidesign.com/showthread...highlight=sc48
Old 01-30-2010, 04:15 PM
Thanks guys. Sorry I didn't find that thread in my search attempts.
So if I understand correctly, despite the way the gain steps may be different on the preamp hardware, the software will direct the hardware to give me the same end result, right? So my mixes/snapshots made with a remote stage rack will sound about the same when I move to either a mix rack or an SC48?
Sorry if this is redundant, but I might not have time for a sound check at a festival, so I'm hesitant to try something new...(to me).
Old 01-30-2010, 06:08 PM
The SC48 does NOT have the 8 variable groups. Aux sends 1 thru 16 should match across the 2 consoles, but the extra 8 on the Profile setup won't be available.
How close is the SC48 to the Profile with a MixRack as far as sound goes? TheMAXX VENUE Live Sound Systems 7 11-30-2013 09:20 AM
Profile w/Mixrack or SC48? TheMAXX7 VENUE Live Sound Systems 15 11-30-2011 09:46 AM
Venue Profile and using Outboard Analog Preamps joellegros VENUE Live Sound Systems 13 04-29-2011 10:52 AM
SC48 with profile in control? drewgandy VENUE Live Sound Systems 1 10-27-2009 10:59 AM
Profile and SC48 moving fader issues steveculp VENUE Live Sound Systems 0 08-21-2009 08:00 PM
