Old 03-02-2004, 03:54 AM
jordan23 jordan23 is offline
Default Music Note Question
Is there a table or legend out that shows what one note is on another instrument -
For example a table that would show an A being played on Guitar is a C# on Piano
* Or if anyone knows if all string instruments have the same notes in common
Old 03-02-2004, 05:08 AM
Chris Cavell Chris Cavell is offline
Default Re: Music Note Question
"A" on a guitar is "A" on a piano.
Cavell Studios
Old 03-02-2004, 05:29 AM
Okay, so I was a little cheeky there,... anyway, yes, all stringed instruments usually contain e,a,d,and g in either ascending or descending order. The reason the guitar having more strings doesn't follow in order around the circle of fifth's ( b and e instead of c and f) is to make things easier on your fingers. The guitar, as well as all other stringed instruments are NON-transposing instruments, meaning a C on one instrument is the same as a C on any other non trnasposing instrument, such as a piano. The octaves may be different, but the pitch letter is the same. There do exist transposing instruments such as saxophone. Here are a few sites that might help you with those instruments:
A simple description of transposing instruments
transposing explained
A comprehensive list of orchestral instruments and whether or not they are treated as transposing
I hope this helps.
-Chris
Cavell Studios
Old 03-02-2004, 06:06 AM
YOU DON'T ROCK TOO MUCH - THANKS...
Old 03-02-2004, 07:57 AM
Roy Howell Roy Howell is offline
Interesting comeback...
rh music
Old 03-02-2004, 11:28 AM
homerg homerg is offline
Apparently Jorda23 has a limited vocabulary in music as well as English.
ASUS A7N8X-E Deluxe
MD Athlon XP3200+2.20GHZ
Corsair XMS PC3200 400MHZ 1GB
WD EIDE 10GB
WD EIDE 250GB
XP Pro SP1
ProTools LE 6.4
BPM Click and Note Resolution question Matt Rushmore Pro Tools 9 10 08-31-2015 05:12 PM
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
Strike MIDI note question Lugh98 Virtual Instruments 11 10-08-2007 08:19 PM
Music Note Question jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-02-2004 09:09 AM
PT 5.2 midi note question Arnold Drummand MIDI 1 01-14-2004 08:37 AM
