Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 11-06-2003, 05:22 PM
shameeta shameeta is offline
Default Bounced files
Hi
Was just wondering if anyone knows how to listen to bounced files using protools. They are in wave format but should be able to be accessed if I want to do further editing on it.
Thanks for your help
Shameeta
Old 11-06-2003, 06:01 PM
RinnyTin RinnyTin is offline
Default Re: Bounced files
when you bounce to disc, choose the "after bounce import into session" option, the bounce will then appear in the regions bin and you can drag it into the session and listen to it. Otherwise, just make a new PT session for .wav 16-bit files, or whatever your bounces are, and then "import audio to track", pull the files into the session.
Old 11-06-2003, 09:41 PM
InSights7 InSights7 is offline
You can load them into Toast 5.X, quit ProTools and listen to them through your Digidesign hardware. Hope this helps.
Dan Matthews
InSight Sound Recording
Loveland, CO
(970) 663-1650
InSight Sound Web Page
Old 11-07-2003, 10:17 AM
Digiquick Digiquick is offline
You can also choose one of the <import audio> features and listen to them from the dialog box.
Old 11-09-2003, 07:36 PM
Hi
Could explain this feature a little further. Not very technically inclined.
Thanks
Shameeta
Pop at the end of bounced files brickroadstudio Pro Tools HDX & HD Native Systems (Mac) 11 07-25-2011 06:42 PM
Volume too low on bounced waw files digidane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 05:49 AM
Bounced files end gets cut off breakie Pro Tools TDM Systems (Mac) 8 05-25-2005 01:26 PM
Recorded bounced files have a pop at end...help ScottFclef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-12-2003 04:18 PM
burning bounced files to cd?? dave813 Digidesign Hardware & Software 2 12-20-2002 07:51 AM
