Old 07-31-2003, 01:03 PM
cwhite771 cwhite771 is offline
Default Re: First midi note Hit always missing.
Originally posted by DooDooDoo:
Any recommandations for good input quantize set up to start with. Or maybe it's not a quantize issue (I'm not too bad with my fingers).
<font size="2" face="Verdana, Arial">Which version of PT are you using? I had a similar problem when I used to use 5.1.3. Never figured out why it did that. To get around it, I'd just put an extra note at the beginning before my track started.
I haven't actually had a chance to do any MIDI in 6.1 yet.
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff.
Old 07-31-2003, 02:20 PM
saeblee saeblee is offline
You will miss the first midi note if you start recording at the exact part where you want midi note to come in. I always stay in slip mode and start record BEFORE the midi notes start. Even if you use a pre roll to give you a couple measures to come in, you'll still miss the midi note if the record starts at that exact measure. I hope this makes sense, but I have experienced this problem before and this solution fixed it.
Good luck Doo DOo Doo!
Old 07-31-2003, 02:24 PM
Sorry, I forgot to mention the most important part. Make sure you record midi in Bars/Beats mode when quantizing. If you're in Minutes/Seconds and then quantize, you'll miss the first note on the one. I guess since the quantize feature is based on bars and beats, using minutes or samples modes can mess you up.
Old 07-31-2003, 09:20 PM
keyboardgod keyboardgod is offline
Are you missing the note when you record or when it plays back?Can you see the note and it won't play?If so I think this because the track is sending a program change to the synth at the beginning of playback.You could turn of receive progam change at the synth end or tack a bit of extra region on the front of the track to give the synth enough time to respond.
Or maybe there's some "chase program changes"command in protools preferences that you could turn off.Don't know about that one but it rings a bell so.......
Have fun
Old 08-01-2003, 12:20 AM
DooDooDoo DooDooDoo is offline
Default First midi note Hit always missing.
HD2, 192, Mac pci express
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
Pro Tools + 61-note MIDI Keyboard = missing low notes! k0000 MIDI 12 03-04-2011 09:29 PM
PT8 - Missing first midi note? InRainbows 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2008 11:42 AM
Midi recording early (and missing the first note) tripstation MIDI 0 09-11-2008 04:14 PM
Missing 1st Midi note ? roaddog215 Pro Tools TDM Systems (Mac) 2 11-16-2000 05:03 AM
