Old 01-17-2020, 03:00 AM
Peterjk's Avatar
Peterjk Peterjk is offline
Default ADAT io without Digital IO?
I was hoping someone could test/verify this:
The ADAT IO on an Avid HD IO, work regardless of the IO cards in the HD IO itself - right? (Lot's of IO in that sentence).
Peter
Old 01-17-2020, 03:12 AM
Default Re: ADAT io without Digital IO?
What is it you are asking? In case you are thinking empty chassis would be functional, it is not. There is a minimum number of cards that need to be present until HD interface works. I am not completely sure if it is two, but at least the analog interfaces are functional if one card fails.
Old 01-17-2020, 12:03 PM
BScout BScout is offline
Peter
Yes.
(They are referred to as the Enclosure I/O or Enc ADAT)
The Enc outputs can all mirror the same signal.
The inputs have to be selected specifically in Hardware setup.
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
ADAT to PTMixPlus via ADAT bridge...digital pops? Phattlippz Digidesign Hardware & Software 2 05-28-2006 05:13 PM
Connecting Adat via digital Rudyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-23-2005 02:34 PM
Tascam Digital / ADAT Digital Conversion Vyper_Mk_II 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-23-2002 02:54 AM
digital I/O :AES or Adat ? phil kerg Pro Tools TDM Systems (Mac) 4 04-16-2002 08:14 AM
ADAT digital....?? Slim Shady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-04-2001 05:49 PM
