Old 10-01-2021, 09:15 PM
anason-records anason-records is offline
Default "Lock To Application" activate/deactivate
it would be great, if i could activate/deactivate the "Lock To Application" option with a programmed key/button.
Maybe it's already possible?
Old 10-02-2021, 03:22 PM
Default Re: "Lock To Application" activate/deactivate
2 things come to mind:
1-nothing says you can't keep Eucon open in the background(not a 1-key solution, but not far off)
2-if you need to keep changing this setting, you should probably leave it unlocked and work that way
Old 10-02-2021, 07:59 PM
well only if you knew what my situation is
i am also controlling via an app called UA Midi Control, Universal Audio Apollo's Console with my 2xS1s which i usually use to control Cubase.
I would much prefer if there were a eucon command to select application and that the system was locked to that application till you choose another one!
but in my case right now, i don't like that whenever i click somewhere else than the DAW the S1 and DAW connection is breaking. Hence i control also the UA midi controller app to control the Console, i can not lock my Avid Controller system to DAW. If only i could go back and fort between applications with a button!
Installing from - "Setup.exe Application" or "Avid Pro Tools Windows installer"? ihate100bees Windows 1 05-08-2021 08:35 AM
"No Update" showing instead of "Current" in Application Manager jsbach Pro Tools 12 1 01-16-2016 03:54 AM
"The licensing service required to activate this software is not running." cmhawke Pro Tools 11 3 08-04-2013 04:41 PM
"Digidesign" Folder not shown in "Application Support" jollyboss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-01-2012 02:12 AM
