Old 03-09-2001, 04:46 AM
gargoyle gargoyle is offline
Default memory and cpu usage
I'm curious about how much ram one alots to pro tools le. Also I upped the cpu usage to 85% from 60% but still couldn't add any more plug-ins. Approx. how many plug-ins should I be able to run? I get to about 6 D-verbs and 4 compressors and it bottoms out.
I am running a G4 466 with 384 ram.
Thanks
Gar.
Old 03-12-2001, 11:24 PM
crowdog crowdog is offline
Default Re: memory and cpu usage
Garg,
I have the same amount of RAM & allocate 90k to DAE & 70k to PT........ but it will not effect the amt of plugs your able to use. You should have seen a nice bump after increasing to 85%. Reverbs are the most CPU intensive plugins of all, if you don't know how to already, you should learn how to set up an aux channel with a reverb as an insert & then send the tracks that you want verb on to that aux channel, that way you can set up 1 or 2 verbs (long & short) on separate auxes & save your CPU for other plugins. This is the way "commercial" studios use their reverbs.
There's also a thread in DIGI001 called "Performance Survey" that you might find insightful, just do a search from the top of the page. Hope this helps
Tony
[This message has been edited by crowdog (edited March 12, 2001).]
___________________________________________
Mac Pro 2010 2 x 2.66 / 40GB RAM / OSX 10.13.6 / PT2020.5 / Metric Halo ULN-8
Old 03-13-2001, 02:30 PM
Thanks.
Figured out the aux track. And how to adjust memory amount.
Gar
RAM memory usage in PT9 / MAC OS Eekay macOS 45 01-20-2011 06:39 PM
64-bit memory usage Ben Hunt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-07-2010 03:29 PM
memory usage? headphono Pro Tools M-Powered (Win) 4 03-07-2008 06:03 PM
Why does memory usage go up every second? brianjanthony Pro Tools TDM Systems (Mac) 11 11-07-2006 09:07 AM
Memory Usage gg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-11-2003 01:39 AM
