No Display on Artist Control
Hey guys...So I've been using the artist control for about seven months now with no problems. I recently used it the other day for a recording session (it was in working order) and haven't updated or changed anything since then. Today I turned on my artist control and the faders moved to their resting position and the buttons lit up as usual but nothing came on the display. I thought the unit had shut off so I checked by opening a PT session and sure enough, all of the faders moved to match the first four tracks assigned and if I touch randomly on the screen it will select whatever track is really there so the touch controls work fine, the problem is purely the display has suddenly stopped functioning. Anyone else experience this? Thanks a lot for the help!
Nico |
Re: No Display on Artist Control
Thanks! I just put it into the hardware test mode and everything functions fine, minus the display so it must be an internal problem. Luckily its under warranty. Thanks again.
Artist Control Display error with OSX Mountain Lion | bg_isagenix | Artist Series | 5 | 10-01-2015 01:58 PM |
Artist Mix Display issue | Dabbler | Artist Series | 2 | 10-03-2013 08:16 AM |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
Artist Color display dim time | tripstation | Artist Series | 0 | 01-02-2012 08:09 AM |
