Digi 003 console not responding. Hosting only
I am running OSX Mavericks and PT 11.01. System has been working fine for about 6 months. I had a CPU usage issue and then had to do a forced shutdown. I then had I/O settings changed messages and for a few prior projects I had a really bad sound in playback but it came right so I can hear everything ok and can record but cannot use my Digi 003 console. The 1394 Host light is on. I am guessing driver or Fire Wire issue but I removed old drivers and reinstalled but no change. I don't have a spare FW cable but I doubt that's the problem.
If anyone has had a similar situation I would appreciate some assistance. I read that FW ports can fail but I don't know how to test this. Cheers.
Any assistance is greatly appreciated, Thunderbird. |
Re: Digi 003 console not responding. Hosting only
Try a different port?
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4 Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control NI Komplete Ultimate 11 Albion One Soundiron Choirs Pianoteq Analog Lab VSL SE/Chamber Strings etc |
I tried changing ports on the 003 but no difference. I have only the one Fire Wire port on my iMac.
Thanks.
Entirely possible that the cable has failed. They do this all the time for no apparent reason. IMPORTANT: Turn EVERYTHING OFF before you plug/unplug any firewire cables.
Amen to that^^^^^ in any case, if you are able to record and playback audio, but have lost the control surface, that suggests you may have the incorrect 003 driver(this happens here if I use the driver for PT10, but run PT11.x).
I believe the PT11 driver is called Avid003 and the PT10 is called digi003 right?
Chris
I will pick up another FW cable and see how that goes.
I tried the various drivers but none worked. The original driver I used was for Mountain Lion OSX and I think PT 10. The console worked with PT 11 but not with PT10. Its all very eratic. Thanks for the feedback, Ill post any results.
Just a short add-on. Is it advisable to use a thunderbolt/fire wire adapter and try running the Digi 003 via the thunderbolt port? If its possible I would just like to rule out the FW port on the iMac being faulty.
Purchased a new FW cable with same result. Tried all the different Avid 003 drivers and had issues with older versions so back to the latest version.
I may try a new download of the Latest PT 11 but I doubt that will fix the problem.
Do a "driver repair"?
003 Console Communicating but not Responding | johnnychuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 04-05-2014 11:56 AM |
digi stoped responding | miz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-12-2006 09:40 PM |
Digi 002 Rack Not Responding | lblstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-07-2006 12:20 PM |
Digi 002 not Responding | prettysmoov | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-08-2005 06:14 PM |
Is it just me, or is Digi responding here more? | who | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-15-2002 11:30 AM |
