Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 03-12-2014, 03:03 PM
stare stare is offline
Default MobilePre output buzzes
I have this MobilePre for some years (1st generation, the grey one).
Recently, the ouput of both the 1/8" jack stere line out and the two 1/4" jacks
started buzzing. Even when nothing is being played, a tiny buzzing signal
is being sent out. It is the MobilePre and not the cables, the amp or the computer or the speakers: with every thing the same, except this MobilePre replaced by another one,
the buzzing sound disappears and everything is fine; also, this MobilePre plugged
into any other (fine) setup makes it start to buzz.
What is causing this? The condensers are a _bit_ swolen after the years,
but that has been for some time already ...
Old 03-13-2014, 07:37 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: MobilePre output buzzes
Do you mean capacitors, not condensers? If not, what do you mean condensers? If you do mean capacitors, then that could likely be the problem and replacing those yourself or having an electronics repair shop replace them might fix it.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
No audio output from MobilePre themanager311 Pro Tools M-Powered (Mac) 1 12-22-2013 06:34 PM
Hums and Buzzes when re-amping WernerF Pro Tools TDM Systems (Mac) 2 11-13-2009 12:40 PM
Mbox Mini Buzzes =( Doquan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-27-2008 11:41 AM
Buzzes on playback wdtaustx Pro Tools M-Powered (Win) 2 03-13-2008 07:57 AM
888/20 Analog Output just buzzes El Guapo Pro Tools TDM Systems (Mac) 3 11-09-1999 09:48 AM
