Old 11-17-2013, 07:15 AM
audiocontrol audiocontrol is offline
Default No GR Metering with CL76 on D-Command
Hello,
I just found that GR metering on the D-Command doesn't work with PT 11.0.3
CLA2a and CLA3a work.
Works fine in PT 10.3.7
Also anybody ?
PT 2018.12, Mac Pro, HDX, S3.
Old 11-17-2013, 07:41 AM
Drew Mazurek's Avatar
Default Re: No GR Metering with CL76 on D-Command
Did it ever work with 11?
If not, sounds like an issue Waves needs to deal with.
www.drewmazurek.com
Old 11-17-2013, 07:50 AM
I don't know as I justed started using PT11, as the softubes came out.
Old 11-17-2013, 08:05 AM
I'd report it to Waves as a possible AAX 64 bug.
www.drewmazurek.com
Old 11-18-2013, 03:48 AM
I just realised that it doesn't show any GR metering at all.
Not in the strip (encoder) not on the meter bridge, not in the dynamic section and even more interessting not in PT.
There also not in the fader section and not in the insert slot.
Can anybody confirm that ?
Old 11-18-2013, 04:57 AM
paulo m's Avatar
paulo m paulo m is offline
The GR meter is completely uncalibrated on D Command when using certain Waves plugins(L family etc).
Even if the signal is just being gain reduced by one or two db´s on the plugin view, the meter on D Command almost reaches the bottom of the scale.
I´m not sure who´s fault is though. The GR metering in PT11 is almost useless too as it´s not value labelled, it just shows that more or less GR is being applied and like in the D Command, it shows more (in apparent view/size terms) that is being applied in reality. If the faders meters have values, why not the GR meter? Puzzles me...
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
D Command Metering bridge kd_special Pro Tools TDM Systems (Mac) 2 01-07-2013 09:29 AM
Metering Bridge on D Command kd_special ICON & C|24 0 05-05-2010 01:01 PM
Command Keyboard Focus mode ' E ' command bug ? vudoo Pro Tools TDM Systems (Win) 2 09-10-2009 05:49 AM
Pre-Fader Metering vs Post-Fader Metering teacherman Pro Tools TDM Systems (Mac) 3 01-29-2008 07:33 PM
Waves Metering on D-Command subwoof ICON & C|24 3 08-24-2006 01:49 PM
