Old 08-02-2012, 08:24 PM
Peterjk's Avatar
Peterjk Peterjk is offline
Default (Official?) AAX BUGs list
I've seen a post like this somewhere, but now I can't find it - so here's what I've found?
Mod Delay III - AAX DSP
Choosing a note length, won't seem to stick, once the session have been saved, closed, and opened again. The actual delay value is recalled properly, even though the note symbol is no longer highlighted, BUT if you then change the tempo after re-opening the session (say in a song writing situation) the delay won't follow since it's set up NOT to follow note value's (because it did not stick).
Reverb One
The mix slider seems to be stick on 100% not matter the position - RESOLVED: See post #6
ReVibe II
Please chip in if you find stuff that repeatable. I'll try it, and update this post.
Old 08-02-2012, 09:48 PM
Dism Dism is offline
Default Re: (Offcial?) AAX BUGs list
Originally Posted by Peterjk View Post
D-Verb
I've had once instance where the MIX slider was not doing anything, but I can't reproduce that error.
Hardly a bug then, no? Sometimes things will do something weird once or twice. You try making 3 billion calculations per second without the occasional blip.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 08-02-2012, 10:20 PM
Peterjk's Avatar
Yeah, you're right Dism, but I just now found out, that it was not D-verb causing the trouble but Revibe II, were the mix slider don't work. It seems to be stuck on 100% no matter the position. And this bug is possible to repeat.
I will edit the list above.
Old 08-02-2012, 11:39 PM
StefB's Avatar
StefB StefB is offline
Same happens on Reverb One
Old 08-03-2012, 01:24 AM
Peterjk's Avatar
On my system, Reverb One is fine.
Old 08-03-2012, 05:22 AM
SOUNDDECISION SOUNDDECISION is offline
Any chance you have the "WET" button selected? When pressed and highlighted yellow it gives you a 100% wet output regardless of the slider position. This is on purpose and a feature to be able to select a 'reverb only' output for use in a send/ return scenario.
Reverb One has this feature as well.
Old 08-03-2012, 05:31 AM
Peterjk's Avatar
Wauv. Yes. I thought it was only an indicator - not a button.
So when the plugin open (in factory default) everything is fine, but as soon as I recall a preset, it's only wet, because all presets are saved like this.
I will remove this from "the list" above.
Old 08-03-2012, 12:33 PM
DigiTechSupt's Avatar
Post Re: (Offcial?) AAX BUGs list
Reproduced here. The actual delay value is recalled properly, but the note is no longer highlighted.
We'll get this logged. Thanks!
(Would you be cool with changing the title of this thread to reflect this specific issue? Might be more effective than lumping multiple issues together.)
Avid Audio Tech Support
Support FAQ
Old 08-04-2012, 04:55 AM
Peterjk's Avatar
Acutally I think it does reflect the specific issue of gathering all BUG's ("features") of the new AAX batch for the developers to change in the next versions? Should it be place somewhere else?
Old 08-04-2012, 07:59 AM
dankin dankin is offline
This seems to imply that it's just the display thats messed up. In my experience the actual delay value is out of time when the session is reopened which makes it totally unusable. I'll check mine to see if the numbers are staying the same but even if they are the delay is not in time when the session is reopened.
HTML code is On
My (working) list of bugs: hoping for fixes... sparky3000 Pro Tools 11 10 06-06-2014 07:43 PM
More PT8 'Configuration List' bugs... Mixmaster Nate Pro Tools TDM Systems (Mac) 6 06-01-2010 07:54 PM
6.9.2 list of bugs Mike Czech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-15-2005 07:04 PM
A list of those annoying bugs for DIGI audio junkie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-04-2002 04:13 AM
Could Digi post an official list of known bugs in 5.1? Stratman Pro Tools TDM Systems (Mac) 24 03-21-2001 07:01 AM
