Plugins Active, But not visible
Recently I encountered a very irritating issue for the first time. All of my plugins seem to still work when inserted, but when selected they don't actually make the plugin itself visible. For example, I am using NI Massive on an instrument track and I can hear that massive is indeed working. However, when I click on the insert where massive is located it turns white but I cant view massive. The same thing happens with any other plugin on any type of channel (audio, aux, instrument...)
I have already tried a clean uninstall followed by re installation and upgrade plus repair permissions and restarted computer. HELP! If anyone has had this problem before or has any type of solution please respond!!! |
Re: Plugins Active, But not visible
Don't know if this helps:
I had a similar problem, the plugin window was almost all of it outside the screen. I found somewhere a key combination that made the PI window pop up top left on the screen. Shift-option, shift-ctrl-option, ctrl-command, don't remember. Might be worth a try. Hide the PI first, then try.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
I am having the same issue now, just wondering if you were able to find any resolution for the problem, or if you were able to find out anymore information on what the problem could be.
8.0.4 allows plugins on active record tracks with LLM? | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-09-2011 10:31 AM |
Are Plugins sill active somewhere? | BigHE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-31-2009 08:24 PM |
active/inactive plugins | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-19-2006 04:23 PM |
WAVES plugins are no longer active in session | denoremusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2005 07:48 PM |
...way to have more active plugins? | frontlinezz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-28-2001 10:13 AM |
