Hardware inserts are making my session sum to mono
I am running a session in Pro Tools 9 through a MOTU 896 HD interface. I have it wired into my patchbay and all of the ins and outs of the MOTU are fully normalled. Whenever I put a hardware insert on my stereo bus aux track, the entire session sums down to mono even if my insert isn't actually patched to any hardware. If I move the insert to another track, that track sums to mono and everything else goes back to stereo. I also tried leaving the insert on my stereo bus and switching my patchbay from normal (it stays mono) to thru (the signal stops) and half-normal (mono also). Another thing worth mentioning, If I put the insert on the stereo bus aux, the signal on that aux's meter goes blank and so does the master fader after that aux, but I can still hear the mono signal. Any ideas as to why this is happening and how to fix it? I'm new to MOTU hardware, so could the issue be with MOTU's internal routing, or am I missing a way to pan hardware inserts Thanks!
Re: Hardware inserts are making my session sum to mono
Can you post a screen grab of you I/O set up page showing how the routing is set up.
Thanks for the reply. It turns out I had to set up routing in Motu's Cue Mix software as well as Pro Tools...I miss my 003
Well, glad you got it sorted out.
making mono track into stereo or double mono in PT7LE | VeganMuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-02-2012 05:36 AM |
mono hardware inserts | Bivens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-13-2007 07:19 PM |
Making Inserts Inactive on Session opening | Sebopath | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-09-2006 10:26 AM |
Dual mono plug inserts | stargazer | Pro Tools TDM Systems (Mac) | 0 | 09-15-2004 04:23 AM |
multi mono/stereo inserts | corTools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-02-2004 12:11 PM |
