Old 03-26-2008, 05:08 PM
Doquan Doquan is offline
Default Mbox Mini Buzzes =(
Just installed mbox2 mini onto computer the outputs on the box have a loud buzz. Buzz goes away if If I uplug the usb cable. Buzz comes back if I even just touch the cable to the usb plug on the computer but not even plug it in? ground problem? any suggestions plz
Old 03-26-2008, 05:39 PM
Seventh Factor Seventh Factor is offline
Default Re: Mbox Mini Buzzes =(
I have the same problem. I also get that 'usb power error' when running pro tools with no files or anything! I tried the mbox mini on a pc and it doesn't buzz. I'm really worried it's my new macbook pro. That buzz sounds like the usb power isn't very clean. I'm searching on here try to and find an answer. PT is almost unuseable at the moment for me.
looking for work in the nyc area!
Old 03-27-2008, 11:41 AM
tbkbt tbkbt is offline
have you tried using a different USB port on your computer? your not using a hub are you, i have experienced that before when using one. if you can use the USB directly on the motherboard or through another USB PCI card, not one of the convienient USB on the side of the tower. also have you tried it in someone's other PC and see if it still hums? i know on macs my tutors mac pro you have to use the left hand side USB for it to power his mbox.
MobilePre output buzzes stare FireWire & USB Audio Interfaces (Mac) 1 03-13-2014 07:37 AM
Hums and Buzzes when re-amping WernerF Pro Tools TDM Systems (Mac) 2 11-13-2009 12:40 PM
Digitizing buzzes and noise - PT 7.1/Firewire 410 hybridd Pro Tools M-Powered (Mac) 2 09-18-2009 03:43 PM
Buzzes on playback wdtaustx Pro Tools M-Powered (Win) 2 03-13-2008 07:57 AM
888/20 Analog Output just buzzes El Guapo Pro Tools TDM Systems (Mac) 3 11-09-1999 09:48 AM
