Buzzes on playback
Recently I have encountered a problem that has made my PTMP 7.3 useless. When recording and playing back I get a short rythmic buzz. It is on all the tracks. It may have started after I installed my firewire card in my mackie onyx mixer and loaded the Traction software but I cannot be sure. I suspect some type IRQ conflict but don't know the best way to diagnose this problem. Up to this point I have never had a problem with PT since installing it over a year ago. Any advice would be appreciated...
Bill in Austin |
Re: Buzzes on playback
Here is an update. I am still having the problem. I now suspect it is a clock synchronization problem. I upgraded from PT 7.3 Academic to PT 7.4 since my last post. The problem remains the same. I have tried using my cubase and logic software and those programs won't even play old projects. PT works but give the rythmic buzzing about every 2 seconds throughout the recording. If there is no sound then there is no buzz. It starts when music begins to play. This problem has completely shut me down now for several months. My hardware is a Delta 1010 and has worked fine for years. All other audio played through other windows programs play just fine. It is only associated with PT or other recording software. Any suggestions would be greatly appreciated...
Are you on Mac or PC? You're in the Windows forum, but you're talking about using Logic, which is Mac only.
Can you clarify that and give us a complete system spec? You may want to look at the Help us help you thread as well. |
MobilePre output buzzes | stare | FireWire & USB Audio Interfaces (Mac) | 1 | 03-13-2014 07:37 AM |
Hums and Buzzes when re-amping | WernerF | Pro Tools TDM Systems (Mac) | 2 | 11-13-2009 12:40 PM |
Digitizing buzzes and noise - PT 7.1/Firewire 410 | hybridd | Pro Tools M-Powered (Mac) | 2 | 09-18-2009 03:43 PM |
Mbox Mini Buzzes =( | Doquan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-27-2008 11:41 AM |
888/20 Analog Output just buzzes | El Guapo | Pro Tools TDM Systems (Mac) | 3 | 11-09-1999 09:48 AM |
