#21
Re: Are Busses at the App or Session level?
//Analog monitor outputs to speakers Analog 1-2 -> 1-2 Out //Track Busses Kik FX -Kik Compressor -Kik Verb Snr FX -Snr Compressor -Snr Verb Gate Triggers -Kik Gate Trigger -Snr Gate Trigger OH Compressor Tom Compressor Tom Verb Room Compressor Drumset Verb 1 Drumset Verb 2 Drumset Submix Perc A FX Perc B FX Perc Submix Bass FX -Bass Amp -Bass verb GTR A FX -GTR A Dly -GTR A Verb GTR B FX -GTR B Dly -GTR B Verb GTR C FX -GTR C Dly -GTR C Verb GTR D FX -GTR D Dly -GTR D Verb GTR E FX -GTR E Dly -GTR E Verb Keys/Synth A FX Keys/Synth B FX Keys/Synth C FX Keys/Synth D FX Keys/Synth E FX Strings A FX Strings A Verb Strings A Submix Strings B FX Strings B Verb Strings B Submix Strings C FX Strings C Verb Strings C Submix Strings D FX Strings E FX Brass A FX Brass A Verb Brass A Submix Brass B FX Brass B Verb Brass B Submix Brass C FX Brass C Verb Brass C Submix Brass D FX Brass E FX WoodWinds A FX WoodWinds A Verb WoodWinds A Submix WoodWinds B FX WoodWinds B Verb WoodWinds B Submix Lead Vox A FX1 -Lead Vox A Dly1 -Lead Vox A Dly2 Lead Vox A FX 2 -Lead Vox A Verb1 -Lead Vox A Verb2 Lead Vox B FX1 -Lead Vox B Dly1 -Lead Vox B Dly2 Lead Vox B FX 2 -Lead Vox B Verb1 -Lead Vox B Verb2 Lead Vox Submix -Lead Vox A Submix -Lead Vox B Submix BG Vox A FX BG Vox A Submix BG Vox B FX BG Vox B Submix Ad Lib Vox FX1 -Ad Lib Vox Dly1 -Ad Lib Vox Dly2 Ad Lib Vox FX 2 -Ad Lib Vox Verb1 -Ad Lib Vox Verb2 SFX FX //Stem Busses Drum Stem A Drum Stem B Perc Stem A Perc Stem B Perc Stem C Bass Synth Stem Bass Gtr Stem GTR A Stem GTR B Stem GTR C Stem GTR D Stem GTR E Stem Keys/Synth A Stem Keys/Synth B Stem Keys/Synth C Stem Keys/Synth D Stem Keys/Synth E Stem Strings A Stem Strings B Stem Strings C Stem Strings D Stem Strings E Stem Brass A Stem Brass B Stem Brass C Stem Brass D Stem Brass E Stem WW A Stem WW B Stem WW C Stem Lead Vox A Stem Lead Vox B Stem BG Vox A Stem BG Vox B Stem Ad Lib Vox Stem Sound Design Stem SFX Stem //Mix Busses MIX1 MIX2 MIX3 MIX4 MIX5 MIX6 So the way I set this all up... the track busses are used in conjunction with the tracks for the mix... I'm using generic names in the IO setup so it stays flexible from one project to the next. For one project Drumset A might be live drumset, Drumset B might be electronic drumset loops, on another project Drumset A might be live drumset, and drumset B might be live drumset Toms overdubs. GTR A might be Acoustic GTR for one project and GTR B might be Power Chord/Rhythm GTR stuff.... on another project GTR A might be Power Chords... and so on... Each group of tracks then gets their outputs bussed to their corresponding stem bus (All the drumset mics and auxes go to Drumset A Stem). There is an audio track for each stem bus, with it's input set to the stem bus. There is also an audio track for each Mix bus. The stem tracks are then all assigned to Output->Mix1 which I use as my main mix... and then I multi-output the other stem tracks to the other Mix tracks depending on what is needed. So sometimes Mix 2 might be No Choir or No Vocals, Mix 3 might be no orchestra, Mix 4 might be Perc and Sound Design Only, and so on. Other times Mix 2 might be No Drums, Mix 3 might be No Background Vocals, and so on. Whatever is needed by the client. The Stem tracks and Mix tracks are always set to input Monitor and are all solo safe'd. as I mix the audio tracks, I'm monitoring through the stem tracks and mix1 track simultaneously. Once I finish the mix, I can record enable all of the stem tracks and all of the mix tracks together and hit record and print all the stems and mixes in one real-time pass. I should also point out that I might not use all of these busses on every mix. If I'm doing a rock power trio then obviously I don't use the brass, strings, woodwinds, etc. But I have them all there and available. I also have templates setup for various types of mixing I do a lot of... so I have a trailer template that has auxes setup for perc verbs and string verbs and so on that I like to use for trailer cues... I have another template for a rock mix, another for a classical orchestra mix, another for Jazz combo, etc... When I'm mixing I can pull from these templates instead of having to setup the tracks, the plugins, the settings and the bussing every time. Makes the mixing process move quicker. Anyway... sorry to bore people but maybe some people find this useful for what they do in their workflow. Enjoy!
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
#22
Thanks Derek, that is very interesting.
If I'm following correctly, your stem tracks are always audio tracks, on input monitor? I've made attempts to do similar kind of templates and have felt like it wound up being more trouble than it's worth because I had to change things on the fly. I can see how your system could be more flexible, as you forgo trying to setup a specific template for your recorded tracks, but have a template for your busses/fx that has enough flexibility to handle a lot of different projects. I've tried do things like have the template specified down to individual tracks, so kick, snr, toms, OHs, and inevitably my current project would have some variation not planned for (like the drummer has a whole kit made out of percussion instruments:) It's a great example of how a DAW is really a general tool, enable a huge variety of workflows. I usually resort to importing my aux tracks and effects from other projects to save time. For fx tracks, I just leave the default bus numbers and name my tracks "fx" followed by the generic bus label. I generally start my standard fx using bus 11-14 for general verbs (for some reason I usually just do mono sends to verbs, probably old habit of saving voices on an HD system), then delays busses 15-30, and other fx above that. So the tracks are named things like "fx11" or "fx31 32" for a stereo bus. This makes it easy to see the track names and associate with sends on a small mixer view. for instrument sub-mixes I'll either use the stereo busses 1-10, or alternately select all the drum tracks (or guitar tracks, whatever), then option-shift "new track" and name it "drumz", and then color it yellow. So my submix tracks are all yellow and end with "z" and dumping to the main mix bus. I don't do stems a lot, but when I do lately, I set up busses for each stem I want, then instantiate post fade sends to those busses on the submix tracks for offline bounce. But man, I do feel like I'm re-inventing the mixer on every frickin' session, you've shared some cool ideas that I think can help. Thanks! |
#23
This is my understanding, as well. I have successfully used Blue Cat Gain Suite to boost tone from -20 to +300 dBFS on a track, then bring it down to -20 dBFS again on the master fader. No distortion, no clipping.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#24
I love the fact you took the time to do that :)
#25
Yes it took me quite a while to kick this habit as well, but now I quite enjoy the ability to pan the reverb send to a different spot to the clean signal. (Depends on the reverb of course - some of them sum the input to mono regardless, so can be a waste of time using stereo sends....)
#26
Busses and sends - session template advice | popcornmama | Post - Surround - Video | 2 | 07-12-2017 03:44 AM |
Import session data bug in 8.1 cs1 having to do with busses | diamondschwin | Post - Surround - Video | 0 | 08-24-2010 08:48 AM |
Session help - sends - inserts - busses - and headphones. | Jono_G | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-27-2010 08:13 PM |
Protools LE 8 session only 16 busses?!?!?!? | sjefkevandriel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-26-2009 05:53 AM |
serious level changes between 32 voice session and 64 voices | agus | Pro Tools TDM Systems (Mac) | 7 | 02-15-2008 10:43 AM |
