Old 03-06-2017, 06:01 PM
Fuzzyc Fuzzyc is offline
Default Can't load editor if Pro Tools is already running
I posted this a couple of months ago but didn't have much luck finding a solution. Since this issues has been a real pain I thought I would try again.
If I load the editor prior to opening Pro Tools everything works great. However if I already have Pro Tools running I can't get the editor to load. All I get is the blank white screen. Again - editor loads fine and works great as long as I load it BEFORE I load Pro Tools. And if I ever accidentally close it out (like you would normally do with a plug in) then the only way to load it again is to close out of my session and start the editor before loading the session again.
I'm running Windows 10 Pro, 64-bit. I was running PT 12.6 until a few days ago. I upgraded to PT 12.7.1 yesterday and the issue is still there.
Is it possible to get anyone at Avid to help me with this? Or has this product been shelved?
Thanks!!
Model: PC AudioLabs Rok Box i9
OS: Windows 10 64 Bit
CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
Memory: 32GB
Internal Hard Drives:
500GB= Programs
1TBGB= Audio
1tbGB= Samples/Back Up
External Hard Drives: Verbatim 1TB USB Drive
RME Fireface UFX Interface/Preamps
Pro Tools 2023
Focal CMS 65 Monitors
Avantones
Old 03-07-2017, 11:34 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Can't load editor if Pro Tools is already running
Did you try trashing the cache?
https://www.youtube.com/watch?v=kWs6fkW2h1Q
Re-installing?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 03-12-2017, 03:49 PM
Yes. I have had to delete the Eleven Rack folder a few times (like in your video) when I would get the white screen "before" ever loading PT. I haven't had that problem in a while now. As long as I load the editor before opening PT everything is fine. It's only when loading the editor after when PT is already running. All I get is the white screen.
I also reinstalled a few times as well.
Just for grins I'll try all of this again and report back soon.
Thanks,
Memory: 32GB
500GB= Programs
1TBGB= Audio
Pro Tools 2023
Avantones
Editor won't load if Pro Tools is running Fuzzyc Eleven Rack 9 11-06-2016 03:37 AM
AES / EBU not passing audio, graphics in editor won't load... DrFord Eleven Rack 1 12-16-2014 05:27 AM
Pro Tools 10 not load plugins,freezing load.HELP javierboz Windows 2 11-08-2012 04:25 AM
Screen Flickers with Pro Tools 8.4 & Melodyne Editor running protoolsuserman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-28-2010 06:04 PM
Running Pro Tools LE 8 on XP and running 2 monitors JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-31-2010 07:38 PM
