Old 05-23-2019, 03:15 AM
c-arts c-arts is offline
Default AVID PRE + HD Native
we have a HD Native System with ProTools Ultimate 2019.5
It is connected to a 192 Digital Interface.
Seperate we also have an old AVID PRE.
We were wondering if there is a possibilty to integrate the AVID PRE in the system?
Kind regards
Michael
Old 05-23-2019, 03:48 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: AVID PRE + HD Native
Just grab a cheap MIDI interface to connect/control -- then you also need AD conversion between preamp and your 192 digital
Janne
Old 05-23-2019, 07:23 AM
YYR123's Avatar
YYR123 YYR123 is offline
For clarification I believe J means
You need one of these to control the Avid pre from the Pt mixer
Digidesign midi i/0 https://reverb.com/item/19236863-dig...m_medium=share
Then you will need any type of A/D converter, b/c your 192 is Digital only....
So something along the lines of this but not limited to this
https://www.sweetwater.com/store/det...rophone-preamp
I believe that clarifies what J mentioned.
Daniel
Old 05-23-2019, 07:30 AM
JFreak's Avatar
Yes. But if the single PRE is the only MIDI device you need to control, just something very simple like this will be enough to control it
Janne
Old 05-23-2019, 09:09 AM
YYR123's Avatar
Ahhh got you, understood- I was unclear about that, thanks
Daniel
Old 06-19-2019, 03:33 PM
DetroitT's Avatar
DetroitT DetroitT is offline
input enable
view in Edit for controls
H/W
5pin DIN ability x 2 (1 in, 1 out)
Al else is XLR analog
Old 06-19-2019, 04:21 PM
If you want to keep using the 192 Digital and have the Digilink capacity then just pick up another 192 analog they are cheap and easier than messing around with extra ADAT boxes etc. If you don't need to digital capacity in the current 192 box then you may be able to swap cards to get the analog inputs you want.
Old 06-19-2019, 04:33 PM
JFreak's Avatar
As far as I remember, the 192digital does not have enough power for the analog cards
Janne
Old 06-19-2019, 05:04 PM
BScout BScout is offline
It does. It just can't support a full configuration (16x16.)
This is Avid's note on it:
http://avid.force.com/pkb/articles/en_US/faq/en319863
We used to run a few digital with analog cards for years with no issue so there's some fear mongering in that note (but also, all our 192s were in a cooled machine room)
Old 06-19-2019, 05:30 PM
Ha, I could not remember the analog board rules, so I was being a bit hand wavey with my answer
Avid HD Native Thunderbolt bleen Buy & Sell 0 11-05-2017 09:44 AM
Avid Pro Tools HD Native Card w/Avid HD Omni I/O Digitaliz Buy & Sell 0 02-19-2017 04:32 PM
WTB Avid Native card (UK) Actionmusic Buy & Sell 0 11-24-2015 12:20 AM
WTB: Avid HD Native Vytis Buy & Sell 3 01-09-2014 07:29 AM
Avid PT9 Native Barry Johns Buy & Sell 1 05-02-2013 07:43 AM
