Old 12-13-2015, 06:03 AM
Tommy1977 Tommy1977 is offline
Default "invalid string position"
today I wanted to open a session from an external usb harddrive that I recorded about one year ago.. Meanwhile I installed a new PC in my studio but I still use Pro Tools 11 as I did last year. When I open the session, Pro Tools starts to load all the tracks but in the end it says that it´s not able to open the session because of "invalid string position"
Any idea how I can solve the problem?
Regards
Tom
Old 12-14-2015, 05:29 AM
joachim's Avatar
joachim joachim is offline
Default Re: "invalid string position"
If you copy the session file and its audio files from the external drive to an internal drive ; does that work ?
What is the format of the external drive (NTFS ?) ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 12-15-2015, 05:16 AM
Originally Posted by Tommy1977 View Post
Regards
Tom
Do other PT sessions play okay? How are you opening the session - do you start PT first and then open the session or do you double click on the session to both open PT and open the session? What computer and operating system are you using? Also make sure the USB ports are not turning off due to the Windows operating system power savings measures (I'm assuming you're on Windows considering you are using a PC and not a Mac).
It could be a corrupt PT install or just not compatible with your operating system.
Jack
QAPLA!
Mutt Lange "1 guitar string-at-a-time" recording? yenomusic Tips & Tricks 12 09-19-2015 04:00 PM
No effect with HEAT's "Drive" knob in the first position to the right midnightrambler Pro Tools 12 3 07-08-2015 02:15 PM
Has "Some regions had invalid bounds and were adjusted or deleted" been fixed? meech Pro Tools TDM Systems (Mac) 22 06-21-2014 12:47 AM
beat detective problems ".....sample position for tick based tracks" Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-26-2009 04:56 AM
OT Let's have your "Best 12 String Electric" songs! lochgarman1798 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 11-12-2002 09:12 PM
