Old 06-01-2010, 04:42 PM
Top Jimmy's Avatar
Default The updater for Structure on Windows fails to locate and update Structure LE
Submitted a support case. The updater for Structure on Windows fails to locate and update Structure LE.
The updater for Hybrid worked OK though.
James Cadwallader
Old 06-01-2010, 04:44 PM
Gothboy's Avatar
Gothboy Gothboy is offline
Default
Well you didn't expect it to work....right away did you????
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core
16 GB RAM
Mountain Lion 10.8.5/El Capitan 10.11
Focusrite Saffire Pro 40
Ableton Live 10/Presonus Studio 3
Old 06-01-2010, 06:11 PM
stonehenge stonehenge is offline
Default Re: The updater for Structure on Windows fails to locate and update Structure LE
what version are you trying to update? maybe it needs a specific version installed first.
Old 06-01-2010, 06:24 PM
necjamc necjamc is offline
I had this problem the first time. I had to unzip the file for it to work (meaning I couldn't just run it from my unzip program). I also had to reinstall structure LE, cause I some how updated to structure the full version on my second shot, so maybe reinstalling then updating helped.
Old 06-01-2010, 07:53 PM
Top Jimmy's Avatar
Thanks for the tips. XPsp3, MPT2. The updater is supposed to recognize which version is installed (full or LE) and update it appropriately.
I always unzip zips before running the contents. I tried re-installing and that didn't change anything.
Here's a pic of the message the updater gives me. http://www.dropbox.com/gallery/25058...Error?h=739db9
James Cadwallader
Old 06-02-2010, 08:54 AM
The only other thing I did when I got that message wss to run the updater from the folder that I installed the mptk2 from.
Old 06-02-2010, 09:03 AM
Avid's Avatar
Avid Avid is offline
Administrator
TJ, what is the exact version number of the Structure.dpm plug-in, and is it in your plug-ins folder?
Administrator
Shifted Music's Avatar
Shifted Music Shifted Music is offline
I get no error message but nothing updates.
I am on a PPC G5 but I could not find any thing in the docs to suggest its Intel only..
Old 06-02-2010, 09:26 AM
Top Jimmy's Avatar
I added a pic of the file properties to my gallery. The main version says 1.0.0.0, but under other info it says 1.0.5316. And yes, it is in the plugins folder.
James Cadwallader
Old 06-02-2010, 02:14 PM
Avid's Avatar
Administrator
TJ, the image showing the Structure.dpm properties that you posted was the same as I saw on my Windows XP system before I ran the update.
After I ran the update, the file version is listed as 1.0.5.10611, which is newer than v1.0.5316
So you are correct that you do not seem to have the updated version on your system if it still says 1.0.5316. I checked and that was the initial release version of Structure LE for Windows.
Administrator
Structure Free unable to load homemade files from Structure 1.0 tuchel Virtual Instruments 0 04-26-2013 09:10 AM
iLok problems for structure...reverted to structure free thisistruth Pro Tools 9 4 12-07-2011 08:04 AM
When I loaded Structure from VIRT pack, Structure Free menu still there. dl0banter Virtual Instruments 2 06-12-2011 02:23 AM
Structure 1.1/Structure Free Sounds/Sample folder DTheone Virtual Instruments 9 03-29-2011 06:25 PM
