Midi notes randomly muted during recording
PT 12.5.0 HD on Mac Os 10.11.6.
When I put a MIDI track in record and play my with midi controller keyboard, other midi notes already programmed in other tracks are randomly muted... then once I finished recording the playback is fine. Ever happened to you ? Using mostly VEP with Kontakt... thanks !
http://www.stevegalante.com |
Re: Midi notes randomly muted during recording
Not that exactly but I just revisted the Loop Playback On, causes the Air Sonivox instruments to play all notes staccato.....
When you turn Loop Playback Off they playback fine.
Thanks for the hint... no it's not that, just tried it
Little update... it may be something related to the use of the VEP Pro 6.
If I move the instrument I am playing/recording to a different MIDI port (not just the midi channel) inside the same instance of the VEP the problem goes away... keep on investigating....
For those interested... after more test I seem to have ruled out VEP Pro 6... the problem when away (at least for now) as soon as I disabled the multi processor support from within Kontakt...
... to be continued....
MIDI notes randomly don't play, although visible in the clip | XJENSEN | Pro Tools 12 | 5 | 01-11-2017 11:03 AM |
12.3.1 midi bug - some notes (randomly) are not playing | muesli | Pro Tools 12 | 4 | 12-04-2015 08:24 AM |
midi notes are being truncated/muted at at random times | kemosabi73 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-29-2010 11:29 AM |
Cursor randomly chopping MIDI notes. | MrChrisos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-07-2009 01:48 PM |
Midi randomly cuts out and sustains notes | MPStevo | MIDI | 0 | 08-15-2009 09:25 AM |
