Consistent audio breakup/stoppage using a 2nd 192 I/O
I read the manual and did a search on this and couldn't find the solution, I am still a beginner at HD and could use some help:
Running PT 12.5 HD Native Yosemite 32gb ram: Upon playback, there is a breakup, then a stoppage....then I get the -9172 and -9129 errors, (clocking issue) asking me to verify sync cables or change buffer sizes, which I've already done. Do I need a loop sync cable? I thought you didn't need one if you're just syncing 2 192's? I'm running HD Native for several months now without a hitch until I connected a second 192 (both 192's are analog, not digital). I connected it up per manual directions (Card > 1st I/O Primary, 1st I/O expansion to 2nd I/O primary) Both 192's are recognized in the Hardware window. Tried all buffer settings. Clock source is Internal on both units. Problem exists in every session now, where as it worked fine when I was using just the one 192, so I think it's relative to a mistake I'm making hooking up the 2nd 192. Any help appreciated.
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM Slate Raven MTi2 / Artist Control |
Re: Consistent audio breakup/stoppage using a 2nd 192 I/O
You definitely need to loop sync them otherwise they are independent of one another and will never clock right. One BNC cable out of the loop sync on the first 192 into the In loop sync on the second 192 THEN another BNC cable from the loop sync out of the second 192 to the loop sync in of the first 192.
That way they are clocked together and the loop sync is a closed loop. I’ve been running an HD I/O and 2 192’s for years and I can tell you I have them all loop synced together and never run into any clocking issues or pops and clicks in the recordings or during playback.
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
Is that a standard cable used to connect TVs?
Nope. Well, the cable might be of the same coaxial type but the connectors are not the same.
BNC connector: https://en.wikipedia.org/wiki/BNC_connector Here is an idea of some of the prices: https://www.sweetwater.com/c811--BNC_Cables
Indeed, Loop Sync MUST be in place and complete(a complete loop of all interfaces). If that doesn't fix the issue, try just the new 192 alone(to see if it operates correctly on its own). I also have a pair of 192's married with a pair of HD IO units and they work fine(my Loop sync connects all 4 units).
remember, with Loop sync, its OUT to IN, Out to IN....(repeat till you come back to the first unit). With a pair of 192's, you need 2 BNC cables
Dave, You saved my butt again. I only had one ordered... had to call back.
By the way, I’m just curious: I thought the second 192 was going to display tracks 17 through 32, but it displays 1-16 in the hardware settings. On the second 192, do I have to designate the first 2 outputs for speaker playback like I do on the first 192?
It can get a little funky when it comes to using the digital IO as you need to setup for the connection you will use(and its somewhat non-intuitive). I use some of the lightpipe IO for a Focusrite OctrPre and it took some trial and error to get it all working(give yourself a few hours where nobody is waiting). Once you get it working, save some screen captures or take notes, because if you trash prefs, those digital configurations will likely get defaulted If you get stuck, PM me and I can send you my screen shots as an example...
Thank you Dave, Yes, I have a lot of notes, screenshots and videos of my processes (always updating when I get things to work better).
I know what you mean about lightpiping'. Been doing it that way with the 8 channels on my Audient 880 pre. BTW, thank you 29Counts, too.
Speaker Breakup | Chris Townsend | Eleven Rack | 23 | 04-26-2011 04:28 PM |
Random Speaker Breakup? | bredo | Eleven Rack | 4 | 03-27-2011 09:19 AM |
Midi and Audio Punch in and Out not consistent. On Purpose? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 0 | 04-26-2010 10:29 PM |
Multiple stoppage | sunking3 | General Discussion | 7 | 01-02-2009 12:16 PM |
Audio breakup diring playback | cvw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-21-2007 02:25 PM |
