  #21
Old 02-13-2018, 09:29 AM
YYR123's Avatar
YYR123 YYR123 is online now
Default Re: CLEAR ALL SOLO shortcut
It’s a wonderful program
https://www.youtube.com/playlist?lis...MuDP7MpPceth30
Daniel
  #22
Old 02-13-2018, 05:33 PM
Originally Posted by pqlior@mac.com View Post
Rich, could you detail how you program that into Maestro? ... is there a way to move the cursor back to its original position?
Also- If I'm on the mixer page, it selects something else...
I don't need this particular macro since I use a control surface, but I just programmed it in about 30 seconds to make sure it would work, and it does.
You might add a condition to not run if the front window does not contain "edit", or you could add a condition to toggle to the edit window if it's in the mix window.
You should check "Restore Mouse Location" in the details dialog for the action (the little gear icon opens it) if you want to return the cursor to where it was.
edit: just uploaded an example; it may need to have exact click location modified to run on your rig, and it's not particularly graceful, but it should give you the general idea: http://s3.amazonaws.com/Deliveries/Clear_Solo.kmmacros
rich@richbreen.com
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
  #23
Old 02-16-2018, 03:44 PM
pqlior@mac.com pqlior@mac.com is offline
Thanks Rich! Could you also attach a screenshot of the macro so I could see what you did there?
Lior
HD Native * PT 2018.7 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
  #24
Old 02-17-2018, 09:28 AM
Why not just download and import the macro that I took the time to upload for you? You can then inspect it yourself.
rich@richbreen.com
  #25
Old 02-20-2018, 03:30 PM
I just did. I changed the cursor location to match mine, but doesn't work... (does nothing)
EDIT: it was in a disabled group folder. I enabled it and now working...
Thanks!
Lior
  #26
Old 11-06-2018, 12:00 AM
Ludicrous Speed Ludicrous Speed is offline
Originally Posted by cshaw View Post
If you have an iPad running PT|Control (which I highly recommend - if only for the soft keys alone) you can assign a shortcut that does this…
The iPad/PT|Control is a great addition to the keyboard and mouse. If you don't have an iPad you can pick and old iPad2 dirt cheap these days.
Damn, according to avid.com -
"SYSTEM REQUIREMENTS
iPad Air or iPad mini 2 or later running iOS 8.3 or later"
Shame, cause I have an old ipad 2 lying around.
  #27
Old 11-09-2018, 08:35 PM
cshaw cshaw is offline
If your iPad runs iOS 8 you should be good to go.
Give it a try. The Control app is free
www.chrisshawmix.com
PT 2018.1
HD Native
Hackintosh i7 3.4 GHz Quad Core Sandy Bridge
Apogee Ensemble
OSX 10.12.6
  #28
Old 11-10-2018, 08:03 PM
Actually, I managed to install it, even though it says no on that link above, thanks! Just gotta set it up, as I don't have wifi at home studio at the moment.
Solo Clear not working on S3 jmkeane Pro Tools | S3 3 10-09-2015 08:34 AM
Clear selected clips shortcut not working hd 10.3.2 dgoodi22 Pro Tools Software (Mac) 7 02-08-2013 05:49 PM
Clear Peak/Meter shortcut not working? theblotted Pro Tools Software (Mac) 8 07-23-2011 03:46 AM
Solo-Yellow, Solo Clear-Green Imagine ICON & C|24 1 05-14-2011 05:55 AM
Keyboard shortcut to clear red clip lights? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-02-2008 11:36 PM
