Old 08-14-2023, 11:16 AM
Benny Mouthon's Avatar
Benny Mouthon Benny Mouthon is offline
Default LKFS real time vs. audiosuite measurement not the same ??
I have to do tweaks to the loudness in a mix, but when I measure a small chunk (say a minute) of the stereo FULL MIX with Waves' WLM or Izotope's Insight 2
in realtime I don't get the same outcome as when I measure the same with Audiosuite rendering, although I'm pretty sure that was the case in the past.
Point is I need to be able to measure a whole 1hr show much faster than realtime but the Audiosuite results aren't correct (they're lower),
I know this because the QC report reads about the same as my realtime measurement.
Is this a setting that has changed somewhere ?? I checked with some colleagues (all running on Mac OS 13.4 and PT 2023.6) and we get the same results..
Not that it should matter but I need to pass ATSC A/85 2013.
Old 08-14-2023, 11:43 AM
its2loud its2loud is offline
Default Re: LKFS real time vs. audiosuite measurement not the same ??
I just did a test here with WLM real time and audiosuite and both results came out the same. How are you measuring the level in realtime? What signal path are you using?
Old 08-14-2023, 11:51 AM
I put a WLM as the first plugin on the FULL MIX record track and measured that in real time playback, then highlighted the first minute and did the same in Audiosuite (=rendered from the AS WLM plugin)
Old 08-14-2023, 11:56 AM
JoeTools1963's Avatar
JoeTools1963 JoeTools1963 is offline
In my estimation, it should be the last plug-in on the master fader. Otherwise, anything on the fader after it will change the loudness. Compression-Limiting etc.
Joe Tools
Re-Recording Mixer/Sound Designer
Nova Scotia Canada
OS Ventura 13.0
Pro Tools Ultimate 2022.12
Mac Studio Max 32GB Ram
OS 10.8.5
Pro Tools HD Accel Version 10.3.8
Mid 2012 Mac Pro 5,1 32GB Ram
Old 08-14-2023, 11:57 AM
Personally, I would never put the plugin on the record track. I always make an Aux Track that has the same input bus as my record track. Then I meter on this aux track, which also happens to be my Monitor path.
If you have other plugins as well on the record track, this will affect the file being recorded.
Old 08-14-2023, 11:59 AM
Or this. Six of one half a dozen of another. Savvy?
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Are you measuring an entire mix or just a track?
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 08-14-2023, 12:55 PM
I'm measuring a stereo WAV of an entire mix. I have a plugin on that record track because I need to measure the result of this track, but I get the same result if I put a send there and have a WLM on an AUX somewhere else.
However, my question is still open: somehow I'm getting different readings using this (or whatever) real time method vs. Audiosuite.
Could be mono mode vs multi-input mode in the AudioSuite plugin. Make sure the AudioSuite plugin is set to multi-input mode and check again?
Scott Gatteño
Old 08-14-2023, 12:59 PM
#$%**@# Scott, thanks mate, looks like that's it !!!
HTML code is On
Clip Gain won’t update in real time during playback on Elastic Time tracks yanos macOS 0 06-03-2012 03:48 PM
Real-Time Bounce to Disk...REAL PAIN Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 201 07-26-2010 08:12 AM
Feeling real stupid...AudioSuite lcollen1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-10-2006 03:14 PM
Quickest way to convert real time to audiosuite?? Beauchampy Tips & Tricks 1 08-02-2006 06:56 AM
DIGI FEEDBACK: 'Real Time' Bounces-Time Effective? csiking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-20-2005 06:41 PM
