Old 12-07-2022, 03:40 PM
Bookerv12 Bookerv12 is offline
Default global mirroring of outputs
Need to mirror main outputs 1-2 to 3-4.
Been a while
bookerv12
Old 12-07-2022, 03:51 PM
dominicperry dominicperry is offline
Default Re: global mirroring of outputs
Setup -> I/O ->
Go to the Bus tab
CTRL-click on the "Mapping to Output" column for MON L-R and add whatever additional output you want from the list.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 12-07-2022, 04:07 PM
Ben Jenssen's Avatar
Or you can select more than one output for your tracks.
One of the many benefits of using a aux track as you main output, not a master fader, is that you can set its output to more than one destination (ctrl-select aux track output on mac), can't be done on a master fader track.
Old 12-07-2022, 04:09 PM
Originally Posted by Bookerv12 View Post
Been a while
Welcome back!
Old 12-07-2022, 05:48 PM
Originally Posted by dominicperry View Post
Setup -> I/O ->
Go to the Bus tab
Dominic
Thanks.
Was in the wrong window...
bookerv12
Old 12-07-2022, 05:51 PM
Originally Posted by Ben Jenssen View Post
Welcome back!
Thanks!
Setting up a system at a public library.
Need to have 4 outputs active without the clients having to multi-route tracks.
Phew....
bookerv12
Old 12-07-2022, 06:06 PM
Welcome back!
Thanks!
Phew....
bookerv12
Old 12-07-2022, 06:08 PM
sorry for double post
bookerv12
Mirroring Outputs... padrino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-07-2007 03:22 AM
please help on mirroring outputs 1-2 to s/pdif outputs! ournature 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 06-13-2007 08:52 PM
Mirroring outputs Gordon -10 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-26-2005 04:54 PM
problem mirroring outputs on 002 skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-31-2004 04:05 PM
Mirroring outputs Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-03-2004 05:55 PM
