  #111
Old 01-18-2020, 08:05 AM
john1192 john1192 is offline
Default Re: Sample Rounding Issue!!!!
Originally Posted by take77 View Post
Hopefully within the new Track Folders we can copy and paste a drum loop.
i am not holding my breath that it will do this out of the Gate ... how could it, if they cannot even get it to work in normal Edit Window NOW !!!
just sayin' !!!! show me the Money !!!
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
  #112
Old 01-20-2020, 05:44 AM
foxes's Avatar
foxes foxes is offline
Agreed
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
  #113
Old 01-20-2020, 07:05 AM
innesireinar innesireinar is offline
A nightmare!!!!!!!!
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
  #114
Old 01-24-2020, 03:17 PM
take77 take77 is offline
Groups of notes get misaligned when I use the cut/insert time feature also.
The other night all I wanted to do was cut a couple bars here and there, insert a drum clip and experiment with a couple different arrangements
Went back and checked the alignment of each track and random note groups all got shifted out of time.
After what was supposed to be quick & easy cuts & inserts.
Up all night.
I finally got lost in all my undo/redos that I just started all over with the original session file & bounced the master down to audio.
Then chopped it into sections then arranged everything with the shuffle feature on.
All just to insert a drum pattern at the beginning and cut the verses in half.
  #115
Old 01-25-2020, 09:23 PM
lgreen100 lgreen100 is offline
Avid has been aware of this issue for some time. http://avid.force.com/pkb/articles/e...ow_To/en430955
Unfortunately their solution (to use ticks instead of samples) does not work.
  #116
Old 01-25-2020, 10:36 PM
dankin dankin is offline
I don’t remember a version of PT that didn’t have the sample rounding issue. Granted I started around version 6 or maybe 7, don’t totally remember, but it seems like this has always been an annoying issue.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII
  #117
Old 01-26-2020, 07:25 AM
Since I switched to Pro Tools with v6 in the 2004 I always had to do with this issue. But while this happened with audio clips only, with v12 it showed on midi clips as well. This is very annoying because when moving or copying midi clips sometimes they lose the first note/chord of the clip.
  #118
Old 01-26-2020, 04:07 PM
foxes's Avatar
Absolutely.
  #119
Old 01-26-2020, 04:11 PM
foxes's Avatar
It's totally ridiculous that this supposedly 'industry standard' is complete crap when arranging midi compositions......their time is ticking with me and my wallet!
  #120
Old 01-26-2020, 04:23 PM
ZEUSS ZEUSS is offline
I don't think it was doing this in version 5. But its been well over a decade plus with this problem. I think it was around end of version 6....?
The worst part, is when someone who is not familiar with this issue consolidates their tracks after doing crossfades and not checking them. The little "sliver" of audio that you can see at the sample level ends up getting 2 crossfades super close together on each cut. This will create a clicking/snapping sound and its because of duplicating and the region not being exactly on the line from this issue. There are micro holes...
Doing quick arrangements with lots of audio is also a pita. There are always gaps where ever the edits are. I have to constantly go in and blow up where the clips are butted against each other to fix all the little holes....
Don't get me started with midi..... notes disappearing etc....
Spikes with VI's....
TIME TO FIX!!! Embarrassing!!!
"We Cant reproduce this". Yeah Right!!! I thought this was PRO tools...
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Sample Rounding budda963 Pro Tools 11 1 07-08-2013 06:07 AM
sample rounding error in pro tools 10??? DarkDayz Pro Tools 10 6 11-02-2011 03:22 AM
PT and Sample Rounding WILL cause Issues when Copying 25ghosts Pro Tools TDM Systems (Mac) 7 07-01-2011 02:25 AM
Sample rounding issues bigdoghat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2007 08:20 AM
Sample rounding, ticks, etc voce Pro Tools TDM Systems (Mac) 1 08-03-2005 05:26 AM
