Old 02-12-2019, 01:27 AM
@tention @tention is offline
Default Keyboard shortcut soundbase
Hey guys,
I'm a German user but I use the UK English version of the fantastic EditorsKeys keyboard because ProTools and some 3rd party apps (EdiLoad) work best that way.
Now I am stuck searching for the physical position of the key I need to press when trying to open the soundbase window.
Could anybody point me in the right direction please?
Thanks
SOUND!
Old 02-12-2019, 02:09 AM
Akiz Akiz is offline
Default Re: Keyboard shortcut soundbase
Originally Posted by @tention View Post
Hey guys,
Thanks
To open Workspace (Soundbase):
Mac: Option+Control+I Windows: Alt+Start+I
Inside Soundbase shortcuts.
Ctrl + Alt + T: Brings up the assign tags popup window. This also works when you have multiple sounds selected allowing you to add tags to large groups of sounds. This is very helpful when categorizing larger libraries.
Ctrl + Alt + Cmd + T: Shows/hides the Tags Pane. If you are only doing simple searches, use this shortcut to hide the Tags pane, then bring it back quickly when you want to browse by category.
Ctrl + S: Once you’ve found the sound you’re looking for, use this to instantly spot the sound to edit insertion. This one is very handy and typically a lot faster than dragging and dropping.
Hope that will help you! You can always refer to shortcut list directly in Pro Tools.
Click on Help->Pro Tools Shortcuts. Chapter 8 is the one you want to look for more shortcuts.
Cheers!
Mac Pro 6.1 "Late 2013", 12 Core 2.7 Ghz, 32Gb Ram, 1Tb SSD, MacOs 10.14.6 "Mojave", Apogee Ensemble Thunderbolt, Softube Console 1,
Avid Artist Mix, Pro Tools Ultimate 2021.7.
Old 02-12-2019, 03:12 AM
Thanks a lot. I had cheked the manual and thought it was someting like | and not I. Sometimes things are a lot easier than expected....
Thanks again
SOUND!
Old 02-12-2019, 04:40 AM
Thanks again
You're welcome!
New Mac Pro - is a Keyboard - just a keyboard ? ..., and Shortcut Covers DavoBali macOS 25 07-23-2014 11:32 PM
Does anyone know the keyboard shortcut for... fancy_terry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-02-2008 07:19 AM
keyboard shortcut for this Andres Gonzalez Tips & Tricks 3 04-03-2007 09:19 AM
Keyboard Shortcut StainedClass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-27-2003 10:34 PM
keyboard shortcut dogpile Pro Tools TDM Systems (Mac) 2 01-23-2002 10:48 AM
