Old 03-05-2018, 10:06 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Default HW Buffer Size at Different Sample Rates
I usually don't record above 48K but today I was doing a track count test recording a 1k signal to 100 tracks with a DSP reverb send and 2 DSP plugins per track at 96K. I had the HW buffer size at 64 (the lowest I can go) for my standard 48K template session before loading a 96K template sessions and adding my tracks and auxes. I just happen to check my playback engine and saw the lowest HW buffer size I could use is 128 at 96K. I decided to change my sample rate to 192K and saw the lowest HW buffer setting was 256. Is this normal when doubling the sample rate and for you Mac guys at 48K, can you get your HW down to 32? Also with this number doubling at higher sample rate is this changing the latency as well or is the latency staying the same and the number changed due to the higher sample rate?
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 03-06-2018, 12:03 AM
BScout BScout is offline
Default Re: HW Buffer Size at Different Sample Rates
Latency and sample rate are related. Doubling the sample rate means the same amount of buffers go by in 1/2 the time. So doubling the buffers restores the same amount of time.
Remember
buffers is equivalent to a measure of samples.
samples / sample rate = latency
You haven't mentioned what your audio card is but all audio interfaces will have a minimum time needed to process incoming audio and that will set your minimum buffer. Since you started with the minimum at a base sample rate, it will have to go up in proportion as you double or quad the base sample rate.
Old 03-06-2018, 10:04 AM
abc1mce2's Avatar
Remember
HDX card and HD I/O.
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 03-06-2018, 01:16 PM
Emi's Avatar
Emi Emi is online now
Well, in my case the lowest latency I obtain with my system is at 96khz. Actually at 192 I have more latency than at 96 with the same buffer size. Maybe it depends on the interface you use....don't know. But normally, at let's say 64 sample buffer size / 48 khz corresponds to 128 / 96 and 256 / 192.
Also at higher frequency rates the quantisation noise gets higher because the anti-aliasing filter is set to a higher frequency. But that's another story...
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Buffer size, sample rate and more... ezolhof Pro Tools 12 9 03-29-2016 02:39 PM
32 sample buffer size w/ pt 9 & 002 vinchenzOH Windows 8 12-16-2010 10:30 AM
PTHD Buffer sizes and sample rates Edgur Pro Tools TDM Systems (Mac) 1 07-05-2010 06:14 PM
32 sample buffer size? CamM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-30-2009 08:16 AM
Is everyone able to run at 128 sample buffer size? lwilliam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 05-04-2001 06:59 AM
